Chalky rub rails - SailNet Community
Blogs
Old 03-12-2010
Waltthesalt is on a distinguished road
Chalky rub rails
Any ideas on coating old rubrails so they don't leak white chalk-like oxidation all over the side. I've used penetrol but found it to be short lived.
Old 03-13-2010
What are the rub rails made of?
Old 03-13-2010
I don't know. It's a white rubber like material with a dull surface. It's the original 70's era material used by Jensen Marine in building Cals.
Old 03-13-2010
svHyLyte's Avatar
Old as Dirt!
svHyLyte is on a distinguished road
Unfortunately, your profile does not indicate the boat you have. For most Cal's however, (you did say Jensen) you may be able to obtain replacement rub-rail material from Steve Seal at Seal's Spars and Rigging . Steve worked for Jensen for years and has made a business out of providing replacement parts and materials for Cal's.
If the foregoing doesn't work for you, you might also get a few more years out of your old rub rail by giving it a good scrub to get down to un-oxidized rubber (it's there somewhere), wiping down the material thoroughly with acetone and then coating it with Nicrocote (contact Marineco through Marinco.com/Brand/Nicro ). The material is designed to refurbish Nicro's white plastic cowl vents but it can be used on about any rubber/plastic so long as the prep's good.
FWIW...
Old 03-13-2010
tager's Avatar
tager is on a distinguished road
I would just go ahead and scuttle her. She won't do with streaks all over her topsides.
Deck Hand Rails alofns Gear & Maintenance 6 07-11-2010 01:05 PM
Removing rub rail jaschrumpf Gear & Maintenance 5 01-21-2010 06:57 PM
repairing very old rubber/vinyl rub rail 2Sheets2Wind Gear & Maintenance 2 10-25-2009 10:23 PM
non teak rub rails and toe boards? jbarros Gear & Maintenance 3 11-04-2003 09:51 PM
Rub Rails AndyM Gear & Maintenance 8 05-12-2003 04:16 PM
SEO by vBSEO 3.6.0
(c) Sailnet 2000-2006
