03-22-2010
Did you ground the boat hard or hit something recently? That looks much like what would happen in the case of a hard grounding. Is there any damage to the front of the keel??
In any case, the repair will have to be done much as described by Mitiempo in his first reply to you. It would probably be worth having a surveyor or fiberglass repair person come look at the boat as the keel-hull join area is a fairly highly stressed area and making sure the repair is robust enough to take the loads involved is key.
