03-15-2010
Originally Posted by redhead78
,I am at a mooring, should I repaint every year, or should I just hit the waterline and high wear areas, and bad spots?
When most people use an ablative paint, they should do the very first coat in a different color than the other coats. This gives them a way of telling how much the paint has ablated and where the high wear areas are. The typical high-wear areas are the leading edge of the keel, the leading edge of the rudder, and the water line. These areas usually need to be painted every season. The rest of the hull may not require it, and that depends a lot on how much you sail the boat.
As BLJones points out, sailing the boat will help keep the growth on the boat to a minimum, by two ways. First, it will allow the paint to ablate—taking any growth that is starting with it. Second, it will expose fresh paint, which is going to be more effective at preventing growth from occurring.
I'd point out that Micron CSC might not be the best choice for your boat. It doesn't begin to ablate very much until you get up to 6-7 knots. A better paint would be one of the Petit ablatives instead, since they start to ablate at a lower speed.
