-   -   HELP I need Cutlass Bearing For Morgan Starrett Jenks 45 (http://www.sailnet.com/forums/gear-maintenance/62909-help-i-need-cutlass-bearing-morgan-starrett-jenks-45-a.html)
LBERTELSEN 03-15-2010 02:15 PM
I Own A Morgan Starrett Jenks 45' 1979, Located In Hawaii
I Will Be Hauling Out bottom paint Soon And Need To Replace My Cutlass Bearing at the same time.
Since I Live In Hawaii Parts Are Hard To Come By Overnight not to mention the cost of laydays, So If Anyone Out There Knows The Part # For That Boat I Would Greatly Appriciate Your Help, Also Any Hints On The Replacement Is Greatly Appriciated Too.
Thanks And Happy Sailing
sailingdog 03-15-2010 02:35 PM
it would help if you said what diameter the prop shaft was, what diameter and length the cutlass bearing was...
Your boat may not be the original specification any longer, so it really needs to be measured specifically.
As for replacing it... read this
LBERTELSEN 03-15-2010 02:48 PM
Dont know the size
I believe the cutlass is the original, the shaft size is 3/4 ( I will have to double check that ), but the lenght I cant measure without taking it out ( I believe ) and the boat is in the water,
I am trying to order one before I haul out to save on laydays, as parts need to be shipped to Hawaii and usually take 3-7 days if in stock.
MAhalo
SEO by vBSEO 3.6.1
