Newbie Advice for Wood Refinishing - Page 3 - SailNet Community
post #21 of 25 Old 03-17-2010
Seņor Member
PorFin's Avatar
Originally Posted by daydreamer92 View Post
If I may also jump onto the newbie woodfinishing train and borrow a photo from my other thread, the exterior wood on my boat -- should I assume it's teak? -- looks like this:
I assume there would be no varnish left on wood that looks like this, if there ever was...?
Daydreamer,
Wipe the wood with water -- if it gets darker, then the finish is gone.
Just a guess here, but my first reaction to wood type was "mahogany." It's kind of hard to tell based on an end grain, but unless my eyes are fooling me (which they do more frequently these days ) I think I can see a bit of a checkerboard appearance on the face of the piece. Don't bet the farm on my guess though...
Have you thought about repairing the outer edge of your dropboard channel? If you do, you should tackle that before you put a finish on the wood.
PorFin is offline
post #22 of 25 Old 03-17-2010
daydreamer92's Avatar
Originally Posted by PorFin View Post
Daydreamer,
Yep, yep, that's on the List. This just happened to be the only picture of the exterior wood that I had handy.
P.S. It is teak -- everything outside is teak and inside is mahogany (Philippine Mahogany, per the surveyor). I took a closer look after your post the next time I was down and there is no checkerboard on the end.
"Tigress"
1964 Tartan 27
It may be a hole in the water, but it's mine.
daydreamer92 is offline
post #23 of 25 Old 03-17-2010
Thanks so much Porfin, that helped a lot. I'll probably go the heat gun route, just one more trip to the hardware store.
jleigh38 is offline
post #24 of 25 Old 06-01-2010
I have recently acquired a sailboat with teak cockpit coamings and caprail. Previous owner had used cetol on it. The cetol is mostly gone on the sun-exposed areas but intact in the shaded ones. So one side of the coaming is almost all bare teak and other has substantial sections with intact cetol. Caprail tops are almost bare and sides are intact. Originally I was thinking of stripping the whole thing and applying varnish. I spent some time this weekend heat gunning till finish bubbles a little and scraping with a "red devil" scraper. After a couple of hours of this work, the enormity of the task has finally started to dawn on me. The scraped areas have a ghastly orange look and I am hoping it will go away with some weathering and/or chemical stripping. I am beginning to wonder if I can just salvage the current situation without resorting to wholesale stripping of the entire area.
My question is , can I just apply more cetol to the areas where its worn off or do I need to strip all the old stuff and then apply cetol or varnish from bare wood ?
Also I plan to paint the deck non-skid with Interlux brightside with silica sand sprinkled in. Should I do the wood first or the deck paint first ?
Thanks,
Junaid
junaido is offline
post #25 of 25 Old 06-01-2010
Semco for teak
I've done most (if not all) of the above processes over the years and refuse to put that kind of effort and time into my exterior teak anymore.
I removed and sanded all of my teak down to bare wood one more time this spring. I will be applying a product called Semco Teak Sealer in the coming days. Next spring (and every spring thereafter) I should be able to wash my teak with soap and water and apply another coat using a foam brush or rag.
Teak Care
oomfh is offline
Advice refinishing teak and holly sole mcagney Gear & Maintenance 21 03-10-2015 09:08 PM
Another newbie seeking boat advice ssll3 Boat Review and Purchase Forum 6 01-05-2010 10:47 AM
Newbie needs boat buying advice captainsandbar Boat Review and Purchase Forum 5 09-06-2009 01:41 PM
Newbie Looking for fiberglass advice natew Gear & Maintenance 20 06-20-2006 07:59 PM
Newbie seeks advice from Sailing Gods scottc Boat Review and Purchase Forum 1 10-28-2001 09:00 AM
