Old 03-16-2010
rjg23's Avatar
SoME Sailor
rjg23 is on a distinguished road
Specific Block Information
Looking for someone to i.d. this unique type of block along with a manufacturer/distributor.
I've looked through Schaefer's, Defender's, and Garhauer's websites for these to no avail.
Thanks
Southern Cross 31
SoME
"If you are lucky to live by the sea, you are lucky enough"
Old 03-16-2010
zz4gta's Avatar
I don't discuss my member
zz4gta is on a distinguished road
Looks like a schaefer cheek block, but the base is what makes it unique. Pretty crappy lead either way, gotta be a better way.
Old 03-16-2010
I agree with ZZ...pretty sure it's a Schaefer block. The lead to the winch sucks though. While the stainless steel rub strake is a nice way to deal with it...moving the block so that the line leads fair would make far more sense iMHO. Your sheets will last longer.
Old 03-16-2010
rjg23's Avatar
SoME Sailor
It's not my boat. I have a similar boat and it doesn't appear that the builder had genoa's in mind when laying the track for the sheets. This owner has a second set of tracks aft of the original track which takes it right up against what appears to be a fairly significant coaming. Seems difficult, given the space, to get the lead correct.
Any suggestions on getting a fairer lead to the winch, including the hardware to do it would also be appreciated. Presently I have snatch blocks attached to the toe rail for the sheets which then run directly to the winch, still without the fair lead. The boat is a Paceship PY-26.
Southern Cross 31
SoME
Old 03-16-2010
ASA and PSIA Instructor
I'd consider raising and angling the winch itself with a pad. Otherwise you need to make the turning block higher, which would create a lot of leverage in its mount.Winch manufacturer's recommend a lead angle of about 8% below 90%, determine the size of the pad size and angle to get the right lead. I've seen solid teak used for pads.
If you lead your sheets to the toe rail, you'll lose a mess of pointing degrees, set the turning block up correctly, then use it with all size jibs, in concert with inboard track.
Old 03-16-2010
GeorgeB is on a distinguished road
You could try a spring loaded stand up block mounted a little further aft on the weather deck. You may have to glass in a pedestal base for it however. Messing with re-angle-ing the winch itself could turn into a nightmare. Have you experienced over-rides with the current setup? If not, and you can stand the extra chaffe and friction of the rub strake perhaps you can leave it as is?
Old 03-16-2010
Instead of raising the winch, which would give the winch more leverage against the mounting bolts and backing plate, I'd put an angled spacer under the cheek block, to bring it a bit further outboard and give it a better lead to the winch.
Information on a Specific Boat Jon Shattuck Buying a Boat Articles 0 01-11-2002 07:00 PM
Navigating from Block Island Bruce Caldwell Cruising Articles 0 08-21-2000 08:00 PM
