holding tank vent - Page 2 - SailNet Community
post #11 of 12 Old 05-21-2010
mitiempo's Avatar
Fittings are spun in to plastic tanks which welds them in from the heat of friction. I have had it done and it only tales a few minutes. But in the shop, not the boat.
Brian
mitiempo is online now
post #12 of 12 Old 05-21-2010
Thumbs up
Originally Posted by good5buck View Post
One more question, but first some background .....
My tank is configured with two separate dip top-mounted tubes and discharges that lead to (a) a manual Whale diaphragm pump and (b) a deck pumpout fitting.
In this case, my mechanic is pushing me to put a ball valve between the tank and the diaphragm pump to improve suction and protect the manual pump. I haven't seen this approach recommended anywhere else under the sun, although it doesn't strike me as a terrible idea. Thoughts?
That's a good change, and will indeed protect the little flap valve inside the manual pump. I added that to the factory system when I replaced all the parts in a factory Ericson waste management system, which incorporates a manual pump to evacuate the tank when out at sea. Drop me a line if you want a link to my project site. It's tedious working in spaces where a ferret would feel right at home... but nothing worth paying someone else $70./hour to do. You also need a good dictionary of swear words...
L
olson34 is online now
Holding tank vent question johnseattle SailNet FAQ 15 02-02-2010 04:01 AM
Flexible holding tank installation sarafinadh Gear & Maintenance 29 10-17-2009 07:46 PM
Portapotty or holding tank on a Tanzer 8.5 rickanlisa Gear & Maintenance 6 10-07-2009 09:17 PM
Holding Tank Questions John_colpitts Gear & Maintenance 14 08-31-2006 06:42 PM
Holding Tanks Tom Wood Gear and Maintenance Articles 0 06-10-1999 08:00 PM
