Filthy Shore Power Cord Solution? - Page 2 - SailNet Community
post #11 of 26 Old 03-17-2010
That would be cool, especially since SSS doesn't work worth a damn as a mosquito repellent, despite lots of claims :-)
I like the split loom solution....simple, inexpensive, likely to work very well.
Bill
btrayfors is offline
post #12 of 26 Old 03-17-2010
Plastics that get gummy after exposure are literally oozing uncured plasticizer. That is often at least slightly toxic and a sign of inferior quality, so beware.
But solvent cleaning or simple degreasers will get it off, and eventually it will stop oozing out. If it is from a reputable vendor, I'd take it back and say "Uncured plasticizer! Oozing! TOXIC! Refund please." and look for a better power cord.
hellosailor is offline
post #13 of 26 Old 03-18-2010
RichH's Avatar
The 'sticky goo' that forms on the surface of vinyl objects after long term exposure to the sun is 'dioctylphtalate' a chemical that is used as a mold release and additive to the PVC molding process.
The good news is the dioctylphtalate is soluble in 'light weight' mineral oils - such as kerosene, mineral spirits, PB-blaster, etc. Just apply/spritz, let soak, rub off with a towel. Works on 'sticky' vinyl 'fenders', yellow power cords, etc. etc. etc.
RichH is online now
post #14 of 26 Old 03-18-2010
GeorgeB's Avatar
My Marinco power cord still gets “gummy” even after ten years (and at their prices, they should come out and clean it themselves!). If the gumminess gets away from me, I go the acetone route. If it is not so bad, then lacquer thinner or mineral sprits. When I keep up with it I use the power cord cleaner from West Marine. I have tried several things to seal it after cleaning. Penetrol did not work for me and the cord cleaners did not last so long. Lately, I been applying a good wax (with UV inhibitors) after cleaning and that seems to keep it looking good the longest.
GeorgeB is offline
post #15 of 26 Old 03-18-2010
How about folding a thin piece of cloth around the cord and running a straight stitch along the edge to make a cover ? Easy, cheap. When it gets shabby just make another one.
Or, alternatively, get some thin cordage and make something like a chain of half or clove hitches close together along the length of the wire to make a kind of bumper around the wire that keeps it from touching the deck. Probably be pretty if you did it.
Or, cut a piece of garden hose down it's length, open it up, and put the cord inside of it, then release so the garden hose makes a cover over the line.
Or, get a better cable ?
Or, get some cable wrap.
Or, get some cardboard tree wrap.
Or, paint the cable.
Or, ... ?
What are you pretending not to know ?
Please support my
wind_magic is offline
post #16 of 26 Old 03-18-2010
Clean then wipe down with armor-all vinyl protectant from any auto part store, and repeat when the cord looks like it needs it.
Ulladh is offline
post #17 of 26 Old 03-18-2010
You could get a few pieces of line and braid or weave them around the cable to cover it, that would look really nice. That is how they make a lot of line we use on boats, braid strands around a core to make a cover, I think it would turn out well if you did the same thing around a cable.
Please support my
post #18 of 26 Old 03-18-2010
T37Chef's Avatar
Wouldn't that do the same thing? I guess white garden hose would last a little longer and not stand out so much as a green one
EDIT: OP, I missed that you know about the Marinco Zip Cover, Oops
Shawn
T37Chef is online now
post #19 of 26 Old 03-18-2010
Here, this is what I was talking about, except instead of ribbon use thin line, and instead of a pole, wrap the cord around your cable to make a braided cover for the length of cable that is on your boat.
Please support my
post #20 of 26 Old 03-18-2010
Mirage 29
sailjunkie's Avatar
Originally Posted by PorFin View Post
Umm -- just a thought here, but wouldn't just cleaning the cord periodically work? Maybe I'm not fully understanding the problem...
OK, the above question may be off-topic, but I'm curious about the answer myself.
Mark
S/V Avatar
Mirage 29'
Port Moody, BC
It's not my fault they named a movie after our boat
sailjunkie is offline
Re: Shore power cord question NewsReader Mass Bay Sailors 0 01-30-2007 07:15 PM
Electrical Power on Board Kevin Jeffrey Gear and Maintenance Articles 0 02-11-2003 07:00 PM
Electrical Power on Board Kevin Jeffrey Her Sailnet Articles 0 02-11-2003 07:00 PM
Boat Battery Power East Penn Manufr. Gear and Maintenance Articles 0 01-18-1999 07:00 PM
