Old 03-17-2010
I33 I33 is offline
I33 is on a distinguished road
Aluminum vs Stainless water tanks
I have stainless water tanks, 30 years old with broken baffles and beginning crevice corrosion. Repairing the broken baffles is going to run $600 per tank. That still leaves me with old thin-wall tanks with some evidence of corrosion and noticeable oil-canning issues.
So, I am thinking about replacements. Custom rotomolded tanks are the most expensive--the molds are the biggest expense. Would sure be nice though. But I will not consider welded seam plastic tanks. Too many reports of split seams.
New Stainless tanks are going to be above $4000.
I would like to hear opinions on using 3/16" 5052 aluminum tanks for water. How much does the chlorine in municipal water accelerate corrosion in aluminum? What other "gotchas" do I need to be aware of?
Thanks,
Gil
s/v Truthsayer
Old 03-17-2010
We had aluminum tanks in our previous boat, we owned it 12 years and it was 10 years old when we bought it... no significant issues. We did periodically muck the tanks out (some crusty white 'nodules' cropped up from time to time) but we never had any serious issues. AFAIK they are still going strong 5 years on.
Whatever way you go try to be sure to have good cleaning access to all baffled compartments!
1984 Fast/Nicholson 345
Old 03-17-2010
mitiempo's Avatar
How many tanks? How large? $4000 seems expensive to me based on the stainless fuel tank I had custom made for $500. Possibly standard size rotomolded tanks will work.
Brian
Old 03-17-2010
wwilson's Avatar
Chesapeake Sailor
wwilson is on a distinguished road
Gil,
I had a 40-Gallon ss tank with baffles custom welded in Annapolis in 2001 for $500. It is hard to believe that inflation has run that rampant since.
wrt your plastic tank idea. Sounds like you have done some homework. But have you checked out the non-custom Ronco marine tanks? They have a long list of seamless tanks for which someone else has paid the non-recurring cost. Here is a catalog .pdf link http://www.ronco-plastics.com/newRon...anks_2010_.pdf
If you could adapt one or more of these to fit your space - it would save thousands and provide first rate water storage.
Wayne
s/v Virginia Dare
Old 03-17-2010
I would recommend going with the Ronco tanks as well.
As for the aluminum tanks, the white encrustations are aluminum corrosion byproducts from the tank being exposed to chlorinated water.
Old 03-17-2010
Waltthesalt is on a distinguished road
I hunted around salvage places till I found a good used plastic than that fit. After cleaning it works fine. I had an aluminum fuel tank built. Need to be careful on mounting aluminum so there's no place where you can have eawater water up against the tank for a prolonged time. I sat the tank down poly strakes to avoid this.
Old 03-18-2010
mintcakekeith is on a distinguished road
Not sure about aluminium for drinking water,isnt there some connection between aluminium cooking utensels and altsiemers ? or is it just me cant remember .K
Old 03-22-2010
timebandit's Avatar
timebandit is on a distinguished road
What bunk!
When I was a airplane fixer upper in the early 60's they told us to be very worried about cuts and alum. poisoning and one other thing, something to do with fires and landing gears. I remember now, the seals in the strut were made from Teflon and when burned it produced a poisonous gas.
When wine makers start using plastic and alum. then I might think about it.
Rick
Mac 25
Copernicus
Southern California
I am not a prejudice racist sexist bigot. I just hate stupid people.
Old 06-12-2010
Shack's Avatar
Shack is on a distinguished road
Aluminum Fresh Water Tank
Faster & SailDog,
I am looking into an aluminum water tank, but I can't decide whether to paint the inside or leave it bare.
Corrosion (an little white globs) is the chief concern, but I think that using distilled water and maybe an annode in the tank might be sufficient to resist corrosion.
What do you think?
I don't want to drink bad water and then ...
"Not just a keel and a hull and a deck and sails..."
Old 06-12-2010
ulferlingsson is on a distinguished road
Anode protection of aluminium? Have you considered anodizing the tank instead? Might be a hazzle to get the cathode inside, but other than that, it should do the trick.
Are You Filtering your Fresh Water? stuartsw Provisioning 38 02-05-2010 01:06 PM
water ballast musolmar Boat Review and Purchase Forum 8 09-26-2004 04:50 PM
Water, Precious Water Michael Carr Cruising Articles 0 09-02-2004 08:00 PM
aluminum water tank CISCOJOE Gear & Maintenance 4 07-15-2002 06:56 AM
Fiberglass Water Tanks ??? ikteros Gear & Maintenance 1 02-14-2001 12:00 PM
