Teak enclosure - latch recommendations needed - Page 2 - SailNet Community
post #11 of 15 Old 03-19-2010 Thread Starter
Unpaid Intern
josrulz's Avatar
Originally Posted by Omatako View Post
Those are 304 grade so actually only marginally better. The others look plated?
Is this thing that you're making going to support the radio or is it just a cover? If it is just a light cover it may be easier just to use Velcro.
It's a panel that will support the VHF, Stereo/CD, and some 12v outlets. I'll have additional space left over to add more later if I want. Of course, I'll still support the larger stereo from the aft end.
The teak is 1/2" marine ply, so it's plenty strong. I think the 304 is fine for interior, but I'm still open to suggestions on how to enclose and keep it as simply (but looking decent) as possible. Here's a pic of a nav station like ours, though it's not our boat. I'm enclosing the space above the shelf, but only about half of it--the half that's over the nav desk.
1984 Sabre 34 Mk I
josrulz is offline
post #12 of 15 Old 03-19-2010
The Gemini latches work well spray with silicone lube on plunger to stop sticking as they will when not used frequently
topsailbeach is offline
post #13 of 15 Old 03-19-2010
chef2sail's Avatar
JOs,
Check out this. I know its not teak, but its a simple solution. It removes easily for work, it pivots so you can work on the wires without removing them, it can fully enclose you stereo to protect it against dust and moisture. We leave the faceplate open when we use it, also have a remote. When we leave the boat or not in use we close the smoked front faceplate. Ours is at/ above our Nav station also
Poly-Planar Stereo Weather Enclosures
Dave
___________________________
C&C 35 MKIII Hull # 76
Parkville, Maryland
(photos by Joe McCary)
Our blog-
Sailing is just the bottom line, like adding up the score in bridge. My real interest is in the tremendous game of life.- Dennis Conner
chef2sail is offline
post #14 of 15 Old 03-19-2010
I don't discuss my member
zz4gta's Avatar
Moroso Quick Fasteners - JEGS
Not sure on stainless though.
Merit 25 # 764 "Audrey"
zz4gta is offline
post #15 of 15 Old 03-19-2010 Thread Starter
Unpaid Intern
josrulz's Avatar
JOs,
Dave
Hey Dave, Thanks for the rec. That's similar to what we have now (for the stereo that is), but we really want to close off the area above the shelf completely. We kind of need a panel, because we need a place to put some 12v outlets at the nav (there really isn't a good spot), plus we need a place for the stereo, VHF, and possible a Link Lite battery monitor. So when you put all those together, well, that's how we got to adding a panel!
And thanks everyone for the ideas on latches. I really appreciate it!
-J
1984 Sabre 34 Mk I
josrulz is offline
Keel pocket seam recommendations needed. fparry SailNet FAQ 3 02-26-2010 01:23 PM
Techniques for Removing Teak Decks Sue & Larry Buying a Boat Articles 0 11-24-2003 07:00 PM
Homemade Teak Decks, Part Two SailNet Gear and Maintenance Articles 0 10-02-2002 08:00 PM
Homemade Teak Decks SailNet Gear and Maintenance Articles 0 08-01-2002 08:00 PM
Bristol Teak Tom Wood Gear and Maintenance Articles 0 11-02-1999 07:00 PM
