Old 03-18-2010
josrulz's Avatar
Unpaid Intern
josrulz is on a distinguished road
Teak enclosure - latch recommendations needed
Hi all,
I'm planning to install a teak panel/enclosure for our stereo and VHF above a shelf in the nav station. I'm a novice woodworker, but I believe I can keep the project fairly simple. Because of the configuration, it would not be possible to set up the panel on hinges. So at the minimum, I would like to install it with some sort of latch at each of the 4 corners so I can remove the panel easily (and over and over, as needed).
Optionally, I would also consider using machine screws, if there's a simple and common way to install a nut on the opposite side. Just so long as I'm not using wood screws, I'd be satisfied.
Can anyone recommend a latch or machine screw configuration that will hold the panel securely, is easy to install, and makes the panel removable?
Thanks!
-J
1984 Sabre 34 Mk I
Old 03-18-2010
Jos—
You could embed t-nuts to receive the screws.....
Another solution would be to use the PYI made fasteners. They make special fasteners for floor boards that would work nicely, but they're pricey.
Old 03-18-2010
josrulz's Avatar
Unpaid Intern
Ahhh just looked up those PYI fasteners. Very nice. That is indeed basically what I was referring to. Although I do see what you mean about the expense--with the needed bits, etc, plus the fasteners. Quite clean though.
T-nuts might be the way to go, simply because the price is right. Are t-nuts a Home Depot sort of thing, or do I need to order them? Sorry, I'm really new to this stuff...
1984 Sabre 34 Mk I
Old 03-18-2010
Part of the solution
bljones has a spectacular aura about bljones has a spectacular aura about
http://www.leevalley.com/hardware/pa...,52800&p=40361
If you want a really clean look, you could avoid fasteners altogether and rout a rabbet in the bottom of the carcass for the face plate to rest in, held in by a full width cleat on the top of the carcass. make the face plate shorter than the overall height of the carcass, drill a finger hole to allow the face plate to be lifted up to clear the rabbet, then pulled down and out to clear the cleat at the top.
Old 03-18-2010
Wouldn't use the ones from Lee Valley, as I don't believe they're stainless steel. Try here instead.
Old 03-19-2010
Omatako's Avatar
Omatako will become famous soon enough
Those are 304 grade so actually only marginally better. The others look plated?
Is this thing that you're making going to support the radio or is it just a cover? If it is just a light cover it may be easier just to use Velcro.
Arthur C. Clarke
Old 03-19-2010
scottyt is on a distinguished road
try looking at jegs, the auto parts place they have a wide selection of quarter turn fasteners, not sure about stainless.
or look at the latch that gemini cats use for the lockers on their boats, you might be able to adapt them. you might even be able to get them from performance sailing direct, so no shipping.
they are shown a few times in this vid
YouTube - Gemini catamaran walk-through
Old 03-19-2010
SD, I'd be worried about stainless if it was an exterior app, or an interior app constantly exposed to air. Neither is the case here.
Old 03-19-2010
deniseO30's Avatar
Lies about her age
It may a bit much advanced to make but a tambor would work nice for an enclosure like that. it's a roll up thingy made of slats.. like you see on big old roll top desks. they can be bought from places like Rockler.com but not in teak i'm sure.
Cable Tambour - Rockler Woodworking Tools
Old 03-19-2010
Cool idea, denise.
Keel pocket seam recommendations needed. fparry SailNet FAQ's 3 02-26-2010 01:23 PM
Techniques for Removing Teak Decks Sue & Larry Buying a Boat Articles 0 11-24-2003 07:00 PM
Homemade Teak Decks, Part Two SailNet Gear and Maintenance Articles 0 10-02-2002 08:00 PM
Homemade Teak Decks SailNet Gear and Maintenance Articles 0 08-01-2002 08:00 PM
Bristol Teak Tom Wood Gear and Maintenance Articles 0 11-02-1999 07:00 PM
