Old 03-19-2010
71Irwin32's Avatar
71Irwin32 is on a distinguished road
Question Just old plates, but what?
I think these are just old backing plates, now sealed, but what was it?
In the close up you can see this is caulk where the bolts used to be.
Hmm?
I think I can safely pull them off and cover'em with G-10 for my purposes.
Any ideas of what they could've held?
Thanks!
Old 03-19-2010
It would help if you posted photos of the outside of that area... then we might be able to figure out what was there.
Old 03-19-2010
AboardIndigo's Avatar
Seen Your Mamba
AboardIndigo is on a distinguished road
As SD said, we can't tell where exactly that is on your boat.
That being said, if we're playing a game, I'm guessing that's the inside of the bow and the backing plates are for long-since-removed mooring cleats on either side of the stem fitting.
Indigo
1976 Catalina Yachts C-22
Old 03-19-2010
71Irwin32's Avatar
Yea, sorry....there's nothing there, just the flat surface of the transom. I knocked (rapped) all around the area, nothing. No difference in sound or feel. You can see the bolt ends for the main stay's stantion plate (if that's what it's called) and the stern light is next to that just above, out of view.
The outside was sealed and finished so nothing shows.
Maybe a horse shoe?...
Old 03-19-2010
mitiempo's Avatar
If those 3 bolts in between are for a backstay chainplate they could benefit from a backing plate I think.
Brian
Old 03-19-2010
I'd second what mitiempo said. If those three protruding bolts are for the backstay chainplate, you really should have a backing plate. If the backing plate is plywood, the nuts should have some big fender washers.
Old 03-19-2010
mitiempo's Avatar
Epoxied g10 would be ideal as a backer for the chainplate.
Brian
Old 03-19-2010
SVCarolena's Avatar
Pearson 303
SVCarolena is on a distinguished road
If that is the transom, maybe those are old backing plates from a swim ladder?
Old 03-19-2010
I wouldn't think so, because they're angled and most swim ladders would have either horizontal or vertical mounting points.... and they're centered around the backstay, which means you would be climbing around the backstay to get aboard.... which also seems like a bad idea.
Old 03-19-2010
71Irwin32's Avatar
Yes, and hold the mast with what....the main's halyard? Tie it to a cleat or such. Not too sure about that one.
Various types of chain plates moonie5961 Gear & Maintenance 15 01-21-2011 02:43 AM
Backing Plates TXS-ALAMO Gear & Maintenance 6 10-31-2007 08:03 PM
Stanchion Backing Plates dakuehn S2 1 01-04-2007 03:47 PM
Stanchion Backing Plates dakuehn Gear & Maintenance 2 11-13-2006 11:45 PM
Backing Plates for C&C34 Stantions fesivo Gear & Maintenance 3 01-20-2001 09:28 AM
