Old 03-20-2010
Yofy's Avatar
Yofy is on a distinguished road
Autohelm troubleshooting
I just installed an ST4000 plus autohelm on Yofy. We have hydraulic wheel steering and the autohelm is working but I'm trying to troubleshoot a couple of problems.
First there is a terrific squeeky sound (like its making an effort to turn the wheel) with every small wheel adjustment. I have taken it apart to check for binding problems but I can't see anything.
Second it is keeping a wobbly track - zigzaging along the track. I asume that might be becaue I don't have a rudder indicator, but I'm not sure.
Does anybody have any suggestions with these two problems?
Manny
SV Yofy
Blog: Sailing in the winds of peace
Website:
Old 03-20-2010
You might also want to check the autopilot's settings, since the sensitivity is somewhat adjustable.
Old 03-24-2010
Yofy's Avatar
I think I may have found my answer for the binding/ squeeky noise problem. Originally I did search here before posting and didn't find anything. Robyn just did a search on google and came up with another thread here on sailnet that looks really helpful.
I have tried to adjust the autohelm's settings sailingdog but perhaps I need to play around a little more. Right now the noise is driving us both nuts so I think I need to solve that first.
Manny
SV Yofy
Website:
Old 03-24-2010
Binding/squeaking is likely in the drive ring.. if it's really an ST4000 then it's an older style (did you buy it used?) The black plastic drive rings are inferior to the new grey ones and often some of the parts can break off inside leading to the binding.
If the boat's steering an "S" track on auto the gain's likely too high for your travelling speed. IIRC if you set it but don't "save" it the gain resets itself each time you power the system up.
1984 Fast/Nicholson 345
TimeLock Marine Pilot 1600 - autohelm instructions wanted sord General Discussion (sailing related) 1 04-13-2010 03:07 PM
Autohelm 6000 autopilot Rskipper Gear & Maintenance 5 09-15-2007 10:46 AM
Autohelm wind instrument troubleshooting help needed duffer1960 Gear & Maintenance 1 10-29-2003 11:03 AM
Autohelm AH 800 furler1 Gear & Maintenance 1 10-28-2003 10:05 AM
Autohelm 4000 Booher Gear & Maintenance 4 10-15-2003 05:09 PM
