03-21-2010
If you've got good access, working from both sides is a far stronger way to do it.  I would not let the epoxy fully cure, but apply the next layer after the epoxy has cured to the point it is still tacky but firm. If it cures much past that point and you're using an epoxy like West Systems, you may have a problem with amine blush forming.
I'd recommend you get your epoxy from epoxyproducts.com and the fiberglass from fiberglasssite.com. I've had very good experience with both of these vendors, especially paul at epoxyproducts.
