Old 03-21-2010
CmdrObvious is on a distinguished road
Keel Repair
Hi All,
I have just acquired this boat, a 24' 1974 Challenger and am getting prepared to launch in about 1.5 months. It will have been about 2 years since it was last in the water so I need to redo the anti-fouling paint.
My concern is with the keel, it looks to me like it should be stripped down and repainted, but I have no experience with this and don't know how to approach it. I am quite handy with tools, and could do it if I know what to do, but I don't want to jump into something way over my head.
My question(s) are:
1. Is the keel in serious shape?
2. If so, is it something I can learn how to do?
3. How do I tell if its an iron or lead keel?
Hmm... can't post links...
Pictures attached
Old 03-21-2010
mitiempo's Avatar
We need the pics. Type the address of the link. The ballast is lead according to the Columbia Yachts site.
Brian
Old 03-21-2010
Gene T's Avatar
Gene T is on a distinguished road
If it's rusty it's iron.
Gene
Currently in Long Beach, CA
Old 03-21-2010
Pictures
I can't link to my flickr photostream yet, but I've attached some relatively low-res pictures, I thought I did the first time
Thanks
Keel Repair-keel_closeup_low.jpg   Keel Repair-keel_port_low.jpg   Keel Repair-keel-starboard_low.jpg
Old 03-21-2010
mitiempo's Avatar
The information I got from the Columbia site said it was lead but that doesn't look like lead. What do the keel bolts look like in the bilge? I'd scrape/sand off a bit of paint to see what is underneath and also the entire area of the keel/hull join. Scrape away any loose material and see what you're left with. You may have to drop the keel and rebed it to the hull.
Brian
Old 03-21-2010
I haven't done much scraping around on it yet, I'm a little afraid of damaging it because I don't know what I'm doing . But I'll take a look at it when I visit it next.
I didn't think to look at the keel bolts for some reason.
Thanks for the help
Colin
Old 03-21-2010
daydreamer92's Avatar
daydreamer92 is on a distinguished road
If it does turn out to be an iron keel, and you need to grind away the rust and recoat it, I found this link to be a good tutorial to how that goes.
"Tigress"
1964 Tartan 27
It may be a hole in the water, but it's mine.
Old 03-21-2010
Given the age of the boat and the weeping rust stains... I would highly recommend dropping the keel, cleaning off the keel and re-fairing it, and checking the keel bolts and replacing them if needed...then re-bedding the whole thing.
Old 03-21-2010
Thanks for all the suggestions, I think that dropping the keel will be necessary.
Does anyone have a ballpark for what that might cost in Canada?
Old 03-21-2010
mitiempo's Avatar
Look at doing it yourself. At $75/hr or so yard rates maybe between 1000 and 2000 or more if done professionally. It's not really complicated or hi tech.
Brian
My First Boat...Boat Term Question... Kacper General Discussion (sailing related) 38 09-23-2008 06:52 PM
Wing, fin, or bulb...what are the trade offs? langousta Gear & Maintenance 17 09-17-2008 04:54 PM
reducing keel/adding fin? abacosol Gear & Maintenance 9 07-01-2007 09:32 PM
Keel Bolt Repairs Don Casey Gear and Maintenance Articles 0 11-10-2003 07:00 PM
Keel Bolt Concerns Don Casey Gear and Maintenance Articles 0 10-12-2003 08:00 PM
