Old 03-21-2010
scottchop's Avatar
scottchop is on a distinguished road
Hull Crack!! How to repair?
Hello all,
I just inherited a nice little dinghy sailer from the neighbor. Sails, rudder, rigging all in like new condition. The one caveat, is the mild crack/hole in the hull near the daggerboard. I am wondering how to go about the best way to fix this heavily stressed spot. Any suggestions? I am not sure how thick the glass is, though it can't be too thick. I wonder about a simple patch, from the outside, wrapped upwards into the daggerboard enclosure?
Any and all advice appreciated.
Here is a pic or two...
Old 03-21-2010
reillyjd is on a distinguished road
Scottchop,
Perhaps a few bags of potting soil and some marigolds, geraniums, and petunias might work.
Actually, its hard to tell from here. Is that photo showing the centerboard slot from the cockpit, or from the outside of the hull?
Old 03-21-2010
LandLocked66c's Avatar
Sunsets and Warm Beer....
LandLocked66c is on a distinguished road
Interested in the responses here... It seems to me anything is repairable!
1971 23' Oday Pop Top
S/V Frida
You can't steer a boat that isn't moving? Just like a life - P. Lutus
Old 03-21-2010
scottchop's Avatar
Hull side. Access holes have been cut into the cockpit side for repair by the PO. No geraniums for this old girl....
Old 03-21-2010
If you have access to the inside of the hull, repair it from both sides. Beef up the interior and make sure the dagger board trunk is well supported. Adding a nice fillet of thickened epoxy all around where the daggerboard trunk meets the hull and a couple layers of fiberglass is probably a good idea.
Old 03-22-2010
scottchop's Avatar
yeah, that was my thoughts on the inside also. what about the outside?
Scott
Old 03-22-2010
You'll want to grind back the glass a bit, but the daggerboard trunk makes it a bit tricky. The majority of the repair will probably be best done from the inside, primarily due to the location.
Scott
Old 03-22-2010
renbluefish is on a distinguished road
"Sailboat Hull & Deck Repair" by Don Casey is a good how to manual.
Crack in hull below waterline 2Sheets2Wind Gear & Maintenance 5 11-01-2009 09:06 AM
High Tech vs traditional-Comments? Pangaea General Discussion (sailing related) 38 08-07-2007 01:07 AM
Spring Hull Cleaning Tom Wood Gear and Maintenance Articles 0 04-05-2004 08:00 PM
Repairing Gelcoat Cracks and Chips Don Casey Gear and Maintenance Articles 0 11-06-2002 07:00 PM
Hull Speed Demystified Steve Colgate Learning to Sail Articles 0 06-10-2000 08:00 PM
