Old 03-22-2010
tiami82 is on a distinguished road
Cal 31 cutlass bearing
I have a 1982 Cal 31. I am looking to replace the cutlass bearing and
can't seem to find the dimensions of the cutlass bearing that I need.
Can anyone help with the dimensions?
thanks
Old 03-22-2010
renbluefish is on a distinguished road
also in the process (different boat), check the shaft diameter and the inside diameter of the strut and/or propeller-shaft tube.
It is also vital to determine whether these measurements are metric or English so you can order the correct bearings
This is info I got from "Boat Works" a great book Selected from Boatworks mag from the Editors osf SAIL mag.
and has a step by step guide on replacing cutless bearings.
Good luck I will be starting mine in acouple months, be sure to post any info you learn during your process.
removing rusty coupler set screws victoria28 Gear & Maintenance 22 01-29-2010 12:35 AM
Repairing Cutlass Bearings Mark Matthews Gear and Maintenance Articles 0 05-07-2002 08:00 PM
Installing a Cutlass Bearing Mark Matthews Gear and Maintenance Articles 0 04-26-2002 08:00 PM
Loose Cutlass Bearing Sue & Larry Gear and Maintenance Articles 0 02-18-2002 07:00 PM
Cutlass Bearing Query SailNet Gear and Maintenance Articles 0 06-06-2001 08:00 PM
