Anti-dish breakers? - Page 2 - SailNet Community
post #11 of 24 Old 03-22-2010
If you're going to use Corelle dishes aboard a boat, DO NOT USE SERRATED KNIVES ON THEM. The serrated knives can damage the plates and make them far more likely to shatter if dropped. Corning actually warns you not to use serrated cutlery on them IIRC.
As for the dish holders, they're fairly easy to make up out of acrylic, especially if you make a heater to bend the acrylic with.
sailingdog is offline
post #12 of 24 Old 03-22-2010
Vagabond in Training
Livia's Avatar
Wow - we've been using serrated steak knives on our Corelle for over a year and they look perfect. Maybe our knives suck?
I couldn't find anything about knives on Corelle's use and care section of their website for the vitrelle/glass version.
A l'eau, c'est l'heure
s/v Estrellita 5.10b, Wauquiez Pretorien 35
Livia is offline
post #13 of 24 Old 03-23-2010
poopdeckpappy's Avatar
LOL,
12 post
11 do's and don't's
1 answer to the question
1955 Blanchard 51 Custom ( I got a woody )
1974 Ranger 33
Friends don't let friends do stupid things alone
poopdeckpappy is offline
post #14 of 24 Old 03-23-2010
Chastened
Ajax_MD's Avatar
Indeed Poopdeck.
It might not be very convenient, but what about just slicing up some thin cardboard to place between each dish? You could also go to any self-storage place and buy a "dishpak". It's a package of bubblewrap sleeves that you place individual bowls and dishes in.
This might sound a little crazy, but once you pick a suitable "shim" to place between the dishes, perhaps you could find some sort of light duty, elastic strap to wrap around the bundle of dishes?
I think I understand the issue- it's not one of breakage, but perhaps an issue of noise from the dishes rattling in their storage?
Aside from newspaper or bubblewrap sleeves, I'm not sure what to suggest for bowls and glasses.
Alacrity, 1981 Tartan 33 #168
Ajax_MD is offline
post #15 of 24 Old 03-23-2010
We use the non skid rubber-like sheets to pad each dish and the bottom of the rack. We use cheap china and haven't broken one yet.
xort is offline
post #16 of 24 Old 03-23-2010
pdqaltair's Avatar
Only a year? Try 45 years for ours.
I'm sure a lawyer wrote the warning... or maybe they just don't give us good knives.
As for answering the original question, we keep the non-skid placemats sort of wraped around them and the cabnets have doors. We have a cat and don't lean much, but we can snap very quickly side-to-side. I can't imagine them chipping in a cabnet, but they could be noisy without padding. We've stored them on edge for many years on one boat - it's safe if there is something soft on the bottom - but I didn't like it as well as flat. They bang around if a few are out.
Writing full-time since 2014
"Keeping a Cruising Boat for Peanuts"
"Faster Cruising for the Coastal Sailor"
"Singlehanded Sailing for the Coastal Sailor"
pdqaltair is offline
post #17 of 24 Old 03-23-2010
You can easily make up separators by drilling holes in two boards (one to go above the dishes, the other below them) and putting thin wood or plastic dowel rods in between the holes. Very little labor and voila, a custom dish rack where they can only rattle a litttle bit between the dowels, with no stacking.
"While it's true, that pyroceram is durable and micro-wavable when this stuff does break it shatters, almost explodes into a million pieces of very sharp chards." I'll vouch for that. If you drop Corelle (the US trademark for that stuff) exactly the wrong way you'll swear a bomb went off. Although Corning used to replace the piece if you sent it back to them. Or sent most of it back to them.
Personally I think serrated knives are best for hacking through things, I've never met a serrated knife that worked on anything I'd want to eat, any better than a straight knife with a well-kept edge on it. Never met a serrated knife that could part a line any better either. Great for sawing wood though.
hellosailor is offline
post #18 of 24 Old 03-23-2010
PDP—
You should learn to count better... at least two answer the question... mine at #11 and post #5
Originally Posted by poopdeckpappy View Post
LOL,
12 post
11 do's and don't's
post #19 of 24 Old 03-24-2010
Yofy's Avatar
It's all going to depend on what your galley storage space allows. I like flat storage for plates best. Then you can stack one plate on top of another (you can put a thin pice of bubble wrap in between for shock absorbers if you need) and you can front the space/locker/box with a covering piece of wood shaped just like in your drawing. You can make another space like that for your bowls. The "U" type opening on the cover will allow you to remove a plate or bowl. Problem is we've never lived on a boat with enough galley space to provide that luxury.
When we bought Yofy she had a rack simular to what T37Chef posted. Its a nice rack, but it stuck way out into our galley and wouldn't hold our bowls. Manny converted a locker by creating a hinged door that flips down to access the plates and bowls. The bowls lie flat, but the plates stand on their edges. The way we have so far found to do this is by using a portion of a plate rack that we cut off of a dish drainer. Its definetly NOT ideal and we are still brainstorming for a better solution. I curse every time I have to access the plates from that locker.
We have ceramic plates and don't regret them one bit. But I would never use cardboard as anti shock absorber material. Cardboard is serious bait for cockroaches!!
Robyn
SV Yofy
Blog: Sailing in the winds of peace
Website:
Yofy is offline
post #20 of 24 Old 03-24-2010
The thin foam that some electronics are wrapped in is a good separator layer for dishes. Doesn't rot, doesn't absorb moisture and doesn't feed cockroaches.
Breakers sailing towards finals (Townsville Bulletin) NewsReader News Feeds 0 01-27-2007 08:15 AM
pan pot dish ? JosephDive Provisioning 3 03-23-2004 02:43 AM
deal breakers maestro Boat Review and Purchase Forum 6 03-22-2004 01:55 PM
The Value of Circuit Breakers and Fuses Chris Brignoli Gear and Maintenance Articles 0 03-24-2003 07:00 PM
breakers and fuses and amps oh my jbarros Gear & Maintenance 6 09-06-2002 11:17 AM
