03-23-2010
On my previous boat, a C&C33, I wanted cockpit speakers but couldn't bear the thought of cutting two large holes for that purpose (I know, kind of hypocritical). The port inside surface of the cockpit had a 6" deckplate as an inspection plate for the fuel filler and vent, so I bought another of the same model, cut out the cover only, and epoxied a marine speaker into the remaining threaded ring (there wasn't enough cover plate material left under the speaker's screw holes). I installed a new deck plate on the opposite side, with its own epoxied speaker in a spare deck plate. Kept the original covers "in case". The hardest part was getting the epoxy to bind the speaker to the ring without running on to the cone. Colourful language was involved, as I recall, but all ended well.
