Old 03-23-2010
QuickMick's Avatar
QuickMick is on a distinguished road
furler maintenance
I have a furler that has the jib removed to rerig as it needs a pennant, and the po had the furl/unfurl setup backwards. With sail down, any routine maintenance I should perform on the track/roller? Or any other bits that could stand an inspection?
thanks,
How inappropriate to call this planet Earth when it is quite clearly Ocean ~ Arthur C. Clarke
Quinn McColly
Yacht Broker
Old 03-24-2010
14432's Avatar
14432 is on a distinguished road
You may get a quicker response if you ID your furler so that those with experience can chime in. You can also go to the mfg. website and download a users manual that would include routine maintenance.
Harken/McLube's Sailcote is a great product to "lube" the moving parts & track.
More info on the PO's setting up the furler "backwards" would be helpful as well.
Old 03-24-2010
The maintenance is going to vary depending on the specific furler. For instance, Furlex has unsealed bearings that need to be greased on a regular basis; profurl uses sealed bearings IIRC, so no bearing maintenance is possible; some others use synthetic bearings that only need be rinsed with fresh water occasionally.
Buying a sailboat -- how to minimize maintenance? Sparohok Boat Review and Purchase Forum 41 12-11-2009 03:21 PM
Roller Furling Lay Up Tom Wood Gear and Maintenance Articles 0 10-21-2003 08:00 PM
Reducing Exterior Maintenance Sue & Larry Gear and Maintenance Articles 0 10-15-2003 08:00 PM
