03-24-2010
That's the way I do it too... no need for anything fancy.
Originally Posted by JohnRPollard
Big screwdriver?
Seriously, I normally just use a screwdriver or small pry bar wrapped in a rag. Generally, you only have to tighten the one adjustment bolt to get it to hold fast. Then you can let go and tighten the pivot bolt.
