How to attach single piece genoa sheets - Page 2 - SailNet Community
post #11 of 36 Old 03-25-2010
MARC2012's Avatar
I have used the cows hitch for on every sail boat I have owned.I did not know what it was called,probably told yrs ago & forgot.Have never had any problems with it.marc
MARC2012 is offline
post #12 of 36 Old 03-25-2010
Wish I never found SN!
SimonV's Avatar
This may sound a bit redundant.....but if you have one continuous jib sheet...how do you end for end it, to share the wear?
Simon
Ericson 39B.
I love my boat
S/V GOODONYA
Brisbane
present location Gold Coast
DELIVERY SKIPPER
Drinking Rum before 10am makes you a Pirate NOT an alcoholic
SimonV is offline
post #13 of 36 Old 03-25-2010
You don't. When it gets worn enough, you cut it and use it as two separate sheets.
sailingdog is offline
post #14 of 36 Old 03-25-2010
SimonV's Avatar
I may Just try it.
Simon
Ericson 39B.
I love my boat
S/V GOODONYA
Brisbane
DELIVERY SKIPPER
SimonV is offline
post #15 of 36 Old 03-25-2010
I went to a single sheet due to difficulities in tacking the two sheets tied with bowlines thru the slot in my cutter rig during light winds. I went out last week in light winds with the single line and was able to tack without the knot hanging up on the baby stay. It looks like I'll have fun removing that constrictor knot at the end of the season.
lancelot9898 is offline
post #16 of 36 Old 03-25-2010
SimonV's Avatar
one problem comes to mind. if and it is an if but does happen. If the furling line parts as has hapened to me you need to reload the line on the drum. to do this you need to hand roll the heady onto the furler, remove the genoa sheets and keep rolling until the required number of turns are loaded, re-attach the sheets. All this while working on the fore deck and probably in shite weather. The knot is going to be about 8 foot above deck.
Simon
Ericson 39B.
I love my boat
S/V GOODONYA
Brisbane
DELIVERY SKIPPER
SimonV is offline
post #17 of 36 Old 03-25-2010
Mine are spliced on, with an additional short length splicing them together just aft of the clew. This allows the line to feed smoothly around the forestay. But it prevents removal without a knife. It's also easier to do with three strand.
WanderingStar is offline
post #18 of 36 Old 03-25-2010
Maine Sail's Avatar
You cut it, flip it, and use bowlines. I have seen larks heads / cows hitches slip but only on a ring and it was under very heavy load. Most of the boats I have raced o use them, I have used them too. Currently have bowlines because I got a great deal on two cut lengths of 1/2" line.
I like the bowline because it is easy to swap sheets for different head sails without needing to have multiple sheets with your multiple head sails. Pulling out a Larks Head can be tedious and more time consuming than tying two bowlines. Bowlines do add bulk and weight to the clew though and can hang on shrouds where the cows hitch does not tend to do these things...
For racing I prefer a Larks Head / Cows Hitch for cruising a bowline. No knot is right or wrong except for the one that slips regularly or comes undone. On my own boats I have never had either slip or come un-done..
______
-Maine Sail / CS-36T
Maine Sail is offline
post #19 of 36 Old 03-25-2010
BarryL's Avatar
adjust for wear
I use a single sheet with a cow hitch. To even out wear, each year I move the hitch two feet or so to one side and then the other. One sheet will be a little longer than the other but no one seems to notice.
Barry
Barry Lenoble
Deep Blue C, 2002 C&C 110
Mt. Sinai, NY
BarryL is offline
post #20 of 36 Old 03-25-2010
One of THOSE!
2Gringos's Avatar
bullpoop on the clove hitch slipping, unless you tied it backward in the grommet.
Expat Life in the Devil's Triangle:
2Gringos is offline
Installing Treadmaster Nonskid Sue & Larry Gear and Maintenance Articles 0 07-11-2004 08:00 PM
Installing Treadmaster Nonskid Sue & Larry Cruising Articles 0 07-11-2004 08:00 PM
The Single Sideband Radio and the Cruising Sailor Sue & Larry Seamanship Articles 0 02-14-1999 07:00 PM
The Single Sideband Radio and the Cruising Sailor Sue & Larry Gear and Maintenance Articles 0 02-14-1999 07:00 PM
The Single Sideband Radio and the Cruising Sailor Sue & Larry Cruising Articles 0 02-14-1999 07:00 PM
