03-25-2010
It sounds like they used a tapped aluminum backing plate for the screws to go into. If that is the case, the threads in the plate could have easily stripped out. I would recommend you call Bavaria and ask them how the backing plates and nuts for the line organizers are actually setup before proceeding. They may have some good advice for you.
