Old 03-25-2010
theartfuldodger's Avatar
theartfuldodger is an unknown quantity at this point
Send a message via Skype™ to theartfuldodger
Nmea connections
I was wondering if anyone could help me with the wiring for a nmea connection using a USB port. What I think is right is that terminal two is data out positive, terminal three is data in positive, and terminal 5 is common or ground. The cable which I have to hook into from the laptop is USB to serial adapter. Now the cable to hook into the USB adapter is wired different terminal one is common terminal three is data in positive and terminal four is data out positive. Should I rewire the cable.
The Artful Dodger II
NFLD and Labrador
33 Morgan O/I
Old 03-25-2010
It would help if you said what equipment you're trying to connect specifically, as some have quirks/issues others do not.
In general, the NMEA Out + wire from the GPS should connect to the #2 pin (RX data) on a DB-9 serial connector. THe NMEA In+ should connect to the #3 Pin (TX data). The only other pin that is typically used in an NMEA connection is Pin #5, the signal ground pin.
Garmin requires that the #5 pin be connected to the Garmin unit's 12 VDC ground or it won't work.
Old 03-25-2010
I'm connecting a nmea signal from a Ray Marine C80 system using the nmea wires to my Fugawi Marine system on my Toshiba laptop through a USB port using the USB to serial adapter.
NFLD and Labrador
33 Morgan O/I
Old 03-25-2010
dreuge's Avatar
Panhandle Sailor
dreuge is on a distinguished road
NMEA to USB via Serial to USB adapter
Hi,
I just connected my raymarine X-5 autopilot to my laptop via a serial to usb adapter. The link below will show you the pin diagram for the NMEA connection. I just made mine from an old serial cable I had. For the usb to serial adapter, I just purchased one on ebay for about $5.
I also added a cable ferrite, as recommended by raymarine. You can get these at electronic shops or from old computer cables. I cut mine off of a usb cable from a keyboard, slid it over the serial cable near the NMEA end and used a heat shrink tube to secure it.
Data Cable
nmea 0183 to RS232 BarryL Electronics 26 12-10-2011 08:29 PM
ST60 Multi NMEA Interface dave8976 Gear & Maintenance 20 07-23-2010 04:14 PM
windsensor for rotating mast, microPC needed for NMEA correction blubaju Gear & Maintenance 5 02-03-2007 05:56 PM
NMEA stds and Magellan 315 GPS mikehoyt Gear & Maintenance 3 06-05-2002 05:03 AM
The NMEA 0183 Data Sentence Jim Sexton Gear and Maintenance Articles 0 10-17-1999 08:00 PM
