Old 03-25-2010
Arclight is on a distinguished road
Sikaflex 291 LOT vs. 3M 4000 UV
I need to fill an 1/8 to 1/4 inch gap between my topsides and the teak toe rail. I'm considering using Sikaflex 291 LOT or 3M 4000 UV. Coments? TIA
Old 03-25-2010
Why would you use a sealant to fill a gap? What is the cause of the gap? Do you have photos of the gap? Filling a gap is often better suited to something like a thickened epoxy, rather than a sealant or caulk.
Old 03-25-2010
Maine Sail's Avatar
Neither. I'd use Sikaflex 295UV or a Polysulfide like 3M 101 if you can still find it, since it has been discontinued. Life Calk is also a polysulfide. UV4000 bonds at about 300 PSI which is way to much IMHO just for gap filling as you will eventually need to reomve it and re-do it..
Dog is correct though in questioning what the gap is from and for as to which material is best suited?
______
-Maine Sail / CS-36T
Old 03-25-2010
josrulz's Avatar
Unpaid Intern
josrulz is on a distinguished road
...a Polysulfide like 3M 101 if you can still find it, since it has been discontinued...
Argh, so that's the reason I can't find it easily. I really like my 3M 101. It doesn't turn yellow, and stays pretty darn soft for a good while. So is Life Calk the last of the polysulfides now? (Sorry not trying to hijack the thread)
1984 Sabre 34 Mk I
Old 03-25-2010
Maine Sail's Avatar
Unless you can find a source who sells the Thiokol stuff in small quantities, yes. Sadly the Life Calk has never held up for me or weathered quite the same as 101 did. Not a bad product but still not 101...
______
Old 03-25-2010
Stillraining's Avatar
Handsome devil
Stillraining is a jewel in the rough Stillraining is a jewel in the rough Stillraining is a jewel in the rough
Life Calk will yellow as well...Im not a happy camper about the 101 deal.
"Go Simple...Go Large"
Relationships are everything to me..everything else in life are just tools to enhance them.
The purchase price of a boat is just the admittance fee to the dance...you still have to spend money on the girl...so court one with something going for her with pleasing and desirable character traits others desire as well... or you could find yourself in a disillusioned relationship contemplating an expensive divorce.
Old 03-25-2010
josrulz's Avatar
Unpaid Intern
So what's the shelf life in an up-opened container? There's still some 3M 101 left around....
And any alternative's for general deck hardware bedding, where butyl tape isn't appropriate (like where some adhesive is needed)? Man, I'll miss my 101...
1984 Sabre 34 Mk I
Old 03-26-2010
Maine Sail's Avatar
Which deck fittings need an adhesive?
______
Old 03-26-2010
josrulz's Avatar
Unpaid Intern
We have a few items, for instance our chainplate covers and teak handrails (56 holes), that are unfortunately screwed into the deck. Though I would prefer them not be screwed, there is no possibility of making them through-bolted, due to the structure/layout of the boat beneath the deck.
Based on I think your recommendation Maine Sail, I use butyl tape whenever the hardware is through-bolted and doesn't need the additional adhesive properties, and I've been using 3M 101 when that's not the case.
-J
1984 Sabre 34 Mk I
Old 03-26-2010
Joz—
So what is the deal with the gap???
Learned a lot last night sharps4590 General Discussion (sailing related) 23 01-18-2010 04:23 PM
Chris Craft Catalina 291 Cruiser jszimmermann Cruising & Liveaboard Forum 2 09-27-2008 02:40 PM
interfacing GPS to Autohelm chuck711 Gear & Maintenance 4 10-28-2003 10:31 AM
