03-26-2010
Originally Posted by CLucas
Thanks. McLube Sailcote is a great product and is terrific in sail tracks, headsail foils and a lot of other places, but I'm not certain this is right application. I'm looking to prevent the stuffing nut and locknut from seizing -- apart from minor adjustments, I shouldn't have to touch the stuffing box for a few years. Sailcote would definitely lower friction, but a dry lubricant isn't going to do the job I need it to do over the long haul and won't survive in that environment.
For now, I think I'm going to go with Lanocote.
Personally I would clean them with a brass brush, put them together, and only after final adjustment when the nuts have been locked against each other would I coat the whole kit & caboodle with Lanocote using an acid brush.
Coat it after not before. There are some things I do lube but stuffing box threads are not one of them..
Having seen the results of a stuffing box nut that spun off the shaft when put into reverse I prefer to not lube the big nut or the little nut or the threads before tightening. I have also never seen a stuffing box I could not break the nuts free on no matter how green with verdigris.
Coating it after its tight will still minimize corrosion/verdigris..
______
-Maine Sail / CS-36T
