03-26-2010
The breakers on Quickmick's boat are definitely not marine grade. They're home depot material stock Square D brand... Here are the photos:
The wiring is probably ROMEX and the stuff is probably wired with wire nuts... all of which are bad ideas on a boat. This stuff needs to be replaced ASAP.
The marine stuff is pretty standardized. If you need a shorepower panel, sailorssolutions.com has a nice little one for fairly reasonable money. Looks like this:
They also sell a decent heat shrink terminal ratcheting crimper for far less than WM, only $39.95...
Sailnet usually has some good prices on electrical gear, so worth giving them a shot at it...and defender's spring sale is going on right now, ends this sunday...so they're worth a look too.
