Leaky chainplates - SailNet Community
post #1 of 19 Old 03-26-2010 Thread Starter
Leaky chainplates
What product do I use for re-sealing my chainplates? I have searched the forums and have seen totally conflicting answers. Poly? 5200? Silicone?
Thanks in advance guys
Yankee22 is offline
post #2 of 19 Old 03-26-2010
Butyl Tape is a very good choice, especially if your chain plates have a metal cover that comes down on top to fit flat on the deck.
If you have questions I'd recommend you read my Marine Sealants In A Nutshell post.
sailingdog is offline
post #3 of 19 Old 03-26-2010
Maine Sail's Avatar
Just took mine off last week for the first time in 31 years. BONE DRY..........factory bedded with gray butyl tape. Will be going back together with the same..
______
-Maine Sail / CS-36T
Maine Sail is offline
post #4 of 19 Old 03-26-2010
Where can you buy butyl tape?
sailhog is offline
post #5 of 19 Old 03-26-2010
RV supply stores, glass repair shops, local hardware stores, etc.
Or online here.
post #6 of 19 Old 03-27-2010
Unpaid Intern
josrulz's Avatar
Just took mine off last week for the first time in 31 years. BONE DRY..........factory bedded with gray Tremco butyl tape. Will be going back together with the same..
Hi Maine Sail, in light of 3M 101 disappearing fast, would you still recommend polysulfide instead of butyl tape on chainplate covers that are not through-bolted? Or do you think butyl tape might be sufficient for something with so little load on it?
Yankee22, for what it's worth, I've been using butyl tape anywhere the hardware is through-bolted and does not need the adhesive properties really, just the sealing. This is most of my hardware. In other instance, I use polysulfide--generally 3M 101, but 3M has stopped making it. Life Calk is similar, but I prefer 101.
1984 Sabre 34 Mk I
josrulz is offline
post #7 of 19 Old 03-28-2010
Sabreman's Avatar
The timing of this thread is fortuitous. I'm in the process of repairing a portion of a rotted bulkhead and will be rebedding my chainplates. From Dog's quote below, it seems that butyl tape is the way to go. I also have to rebed a stanchion and genoa track so it looks like butyl is what I should use. It appears that Sabre used butyl tape in the 80's when the boat was manufactured.
It is great for bedding deck hardware, especially things like chainplates, where a certain degree of movement is unavoidable. It has the greatest materials compatibility of all the sealants and is also probably the least expensive of them. It is probably the best sealant for any hardware above the water line that is through-bolted and doesn’t require the adhesive strength of polysulfide or polyurethane based bedding compounds.
Dog - Do you still agree that butyl tape is the way to go?
Sabre 38 "Victoria"
Sabreman is offline
post #8 of 19 Old 03-28-2010 Thread Starter
I couldn't find it at Home Depot so I guess I'll just order it online. Any tips to the application?
Thanks guys
Yankee22 is offline
post #9 of 19 Old 03-28-2010
Yes, IMHO, the only deck hardware that should be bedded using something else is stuff that requires the strength of the adhesive and isn't through-bolted. If it is through-bolted, then butyl tape is the way to go.
You can get butyl tape at most glass repair shops, rv supply stores, or local small hardware stores—the big box stores won't carry it usually... odd...but true.
post #10 of 19 Old 03-29-2010
You answered my question sailingdog. To expand a bit, do I cut a slot in the tape to fit over the chain plate, snug it up to the edges of the plate and add enough tape on each side to cover the area of the metal cover Lay the cover on and use a sharp point to punch holes in the tape for the thru bolts
weephee is offline
Chainplates Newport 30 MBesant Gear & Maintenance 6 01-22-2009 03:09 PM
Replacing Chainplates FullandBy Gear & Maintenance 3 02-09-2007 04:13 PM
Sealing Chainplates mikehoyt Gear & Maintenance 6 08-25-2003 07:26 AM
Rebedding Chainplates C&C 30 RobGallagher Gear & Maintenance 2 03-30-2003 08:48 AM
chainplates mary jewell Gear & Maintenance 1 10-25-2002 06:10 PM
