03-27-2010
Originally Posted by 71Irwin32
You're missing my whole point. The way I'm doing it, it'll blend in and look like part of the original building. The wood will be encased in epoxy and painted.
I understand that. You still could have made it look original, but also removable, done it many times as most builders do.
The only difference is that the cleat could have been held in-place by four studs then the seam between headliner and furniture could have been finished in any number of ways while still allowing the piece to be removed for access at a future date. I just don't personally like to attach something to the overhead of the cabin in case deck access is needed in the future. If that port light needs to be replaced, and you can't find the exact match because the folks who made it are long gone, and the new one uses an internal flange you'll be having a tougher time modifying that piece in-place than if you could remove it and modify it..
Matching the factory gelcoat, and blending it, will be more difficult than using a caulked seam, piping or a small piece of painted trim to hide the transition..
Just different thought processes that's all..
______
-Maine Sail / CS-36T
