stripper does npt work and sanding will take forever... - Page 2 - SailNet Community
post #11 of 13 Old 03-29-2010
poopdeckpappy's Avatar
One of our boats I used Peel Away, it's like a wallpaper paste that you either brush or roll then cover with a paper ( supplied ) worked pretty good as long as you let it work and do it with good temps ( the warmer the better ), if a stripper doesn't remove the old finish, just prep the deck,prime and finish
1955 Blanchard 51 Custom ( I got a woody )
1974 Ranger 33
Friends don't let friends do stupid things alone
poopdeckpappy is offline
post #12 of 13 Old 03-29-2010
Topsides = the outer skin of the hull between the waterline and the deck, and that's normally resin gelcoat on a plastic boat. Not paint, so paint stripper won't bother it. Oven clear, like lye, will soften and destroy it eventually but gelcoat isn't just cosmetic, it is keeping moisture out of the laminate. You don't normally want to remove it, you would sand/refinish/repair it and then apply a new coating ("paint") OVER it.
Make sure of what you've got before you destroy it.
hellosailor is offline
post #13 of 13 Old 03-29-2010
Originally Posted by hellosailor View Post
Topsides = .
Gawd damnit, I always think of going " topside " as in going on deck..............old brain I guess.........sorry
1974 Ranger 33
Tips For Compound, Polish & Wax Maine Sail Gear & Maintenance 304 04-20-2017 07:58 PM
The Salt's Corner Table smackdaddy General Discussion (sailing related) 129 06-18-2013 04:46 PM
Refitting an Older Boat Sue & Larry Gear and Maintenance Articles 0 12-16-2000 07:00 PM
