Old 03-28-2010
john232 is on a distinguished road
stripper does npt work and sanding will take forever...
I have tried to strip the topsides on a 37 foot boat but the strippers I have tried will not cut it and sanding a square foot of paint with takes 15 minutes. The only thing I can think of to do is use a grinder which can cause major problems when I have to fare the topsides for blue Awlgrip. HELP.
Old 03-28-2010
WanderingStar is on a distinguished road
I use a heat gun and sharp scraper, but my boats are wood.
Old 03-28-2010
xsboats's Avatar
xsboats is on a distinguished road
If it is that hard to take off the paint, why does it have to come off?
Old 03-28-2010
Two many boats!
degreeoff is on a distinguished road
you sure its paint and NOT gelcoat?
I love to sail, coming from a Swordboat capt's loin one would think I'd of caught the bug long before now! Oh well, this ones for you Bisque...(My Father may he RIP)
Now If I could only stay away from working on the damn things I could sail more!
Current boat...
-1985 c-30 TR DONE!! after two new engines and too much labor she floats sails and steams....
Old 03-28-2010
Almost land locked sailor
Freshbreeze is on a distinguished road
Are you trying to strip the Gelcoat?
If not, keep at it! it took 2 months to sand the Deck, Cockpit, Topsides, Hull, and Keels of a 20 foot bilge keel yacht.
I learnt a lesson about stripper - ensure you throughly wash it off with water after it has done it's job. Another bit of advice for paint stripper - cover it over with clingfilm. It should make it easier!
Old 03-29-2010
FishSticks's Avatar
Old Gaffer
FishSticks is on a distinguished road
If you connect a vacuum to the sander the job will go much faster, you will use way less paper and you might live longer by keeping the dust off you. And it's much better for the environment. The vac keeps paint from building up and melting into the paper. The Fein vacuum is a great one for this type of project and super useful to have in your shop.
Never sail closer to the wind in degrees than your age
Old 03-29-2010
jarcher's Avatar
jarcher is on a distinguished road
How much of the deck are you doing? If the entire thing, maybe you want to have it soda blasted?
Helios
Scampi 30 MK-IV
Old 03-29-2010
xort has a spectacular aura about xort has a spectacular aura about xort has a spectacular aura about
I'll second the question about what it is. Do you know it is paint? Do you know if it's a 2 part paint or a single part paint? What are you painting over it?
IIRC, if you are painting with a 2 part paint you have to have a 2 part paint under it (or gelcoat) if you are painting with a single part paint, you can have a single or a 2 part or gelcoat under it.
Old 03-29-2010
tager's Avatar
tager is on a distinguished road
Scraper, then heavy grit paper to even it out. Soda/sand blasting may be economical.
Old 03-29-2010
jarcher's Avatar
Soda blasting will remove all the paint but leave the gel coat intact. Sand blasting will remove the paint and the gel coat along with it.
Helios
Scampi 30 MK-IV
Tips For Compound, Polish & Wax Maine Sail Gear & Maintenance 172 1 Week Ago 05:50 PM
The Salt's Corner Table smackdaddy General Discussion (sailing related) 125 10-02-2011 06:10 PM
Refitting an Older Boat Sue & Larry Gear and Maintenance Articles 0 12-16-2000 07:00 PM
