03-28-2010
John,
Your idea sounds reasonable to me... after all what do you have to lose. Best case, your idea works and you sail happily for several more years with your old backstay tensioner. Worst case, you mess up the job or the sheaves still don't run free after the repair and you need to get a new one which is where you are now. I'd spend a couple of dollars and an hour or two to try out your plan. Get partially threaded machine screws if you can giving the sheaves a better surface to roll on. Inspect the screws and nuts regularly to ensure they don't back off. Loctite is pretty good.
Good luck... let us know how it turns out.
Dave S
Georgian Bay, Ontario
Catalina 34 - (formerly CS27) "Good Idea"
Reason: correct typos
