Stainless stanchion cleaner? - Page 2 - SailNet Community
post #11 of 22 Old 03-29-2010
albe1066's Avatar
Thanks..
Done .. Sailingdog Thank you..
cheers
albe1066 is offline
post #12 of 22 Old 03-29-2010
Excellent... I'm ordering some more of your product this morning.
cheers
sailingdog is offline
post #13 of 22 Old 03-29-2010
chef2sail's Avatar
Ordered two more quarts of this stuff. Have used it before with astonishing results. Was able to tell the admiral I spent all day working on the shine
Dave
___________________________
C&C 35 MKIII Hull # 76
Parkville, Maryland
(photos by Joe McCary)
Our blog-
chef2sail is offline
post #14 of 22 Old 03-29-2010
tager's Avatar
I have been told by a poster affiliated with spotless stainless that the active ingredient is citric acid.
tager is offline
post #15 of 22 Old 03-30-2010
Almost land locked sailor
So i guess you could clean stainless with standard household products, or even citrus fruits as a buget alternative?
Freshbreeze is offline
post #16 of 22 Old 03-30-2010
So when you hose the Spotless cleaner off does it remove your wax?
saildog1 is offline
post #17 of 22 Old 03-30-2010
albe1066's Avatar
Spotless Stainless will not remove wax. If you have waxed your stainless steel this will prevent Spotless Stainless from reaching the surface to remove rust and free iron.
Spotless Stainless does contain Citric Acid, however there are other components in the solution that are involved in making it effective and delivering amazing results. It is the relationship of these components that makes Spotless Stainless the simplest most effective way to remove rust and free iron that we have found. We tried many different formulations before we got it right..
albe1066 is offline
post #18 of 22 Old 03-30-2010
This may be a problem however the real problem for cleaning stanchions is the requirement for keeping it moist for 30 minutes in 70 degree heat. Other than those two problems it seems like a good product. I need to remove some rust on a stainless steel shaft that goes into the stuffing box and I suppose that I could soak a rag in the liquid and let it sit on top of the shaft for 30 minutes or so and then turn the shaft over and do the same thing on the other side??
lancelot9898 is offline
post #19 of 22 Old 03-30-2010
albe1066's Avatar
Keeping Spotless Stainless Moist
Keeping the solution moist if used in direct sunlight during the hottest part of the day may be a challenge. The product is formulated to minimize drying as much as possible. We were initially concerned drying may be an issue. Based on the feedback we have received from people who have used Spotless Stainless (many in South FL) keeping it moist has not been an issue. We avoid cleaning stainless in direct sun during the hottest part of the day (I want to be somewhere cool anyway).
When we clean our stainless we have a small container of spotless stainless in hand and walk around applying the product with a brush. If we see an area that looks like it may drying we lightly re-brush. It is a very simple process and takes very little time compared to methods that require rubbing, scrubbing or polishing. Effective rust removal and extended time between cleaning with minimal effort and mess were the drivers for us to find a simpler method to remove rust and protect our stainless steel - hence Spotless Stainless..
A funny quote from a user posted on the CSYForum "The best thing I like about it (Spotless Stainless) is,,,you can stand on the dock talking to your friends and drinking a cold one .....and one fellow says " hey I thought you were going to clean your SS today?" and you can reply..." I'm cleaning it as we speak!!!"....priceless ...."
Time is related to temperature. The warmer the better your results in less time. So it may not take 30 mins to get desired results. We use the statement up to 30 mins. All of this is discussed in our faq at FAQ - Spotless Stainless Removes Rust, Protects Stainless Steel . You can read about user experiences at Home - Spotless Stainless Removes Rust, Protects Stainless Steel
Lancelot Spotless Stainless should adhere to your shaft and stay moist without the need of a rag (if not used in direct sun during the hottest part of the day). It is formulated to adhere to vertical surfaces so it should stay on your shaft. The thickness basically provides a media for a suspension that is like placing your stainless in a bath. We use it on our stanchions both horizontal, vertical and the base on the deck - It works..
albe1066 is offline
post #20 of 22 Old 05-14-2010
You could electropolish them
If you feel like, or can remove the stanchions and electropolish them. This would have the added benefit of getting underneath the base (where we see rust all the time). All rust would be removed and the surface rendered fully passive. Whatever you do do NOT use steel wool on stainless. Small particles will embed in the surface and rust will spread to the s/s quickly. I will post a couple pictures showing before/after electropolishing of some 306 and 316 ss tubing.
Metal Finishing Shop Owner for 30+ years.
MetalFinisher is offline
Stainless Cleaner Flfishindude O'Day 3 05-21-2010 11:11 PM
BBQ implements - or - How I tested stainless steel at the hardware store Bene505 Cruising & Liveaboard Forum 5 03-01-2010 02:22 PM
Stainless 101 sailnaway Gear & Maintenance 2 01-28-2005 05:02 AM
Keel Bolt Concerns Don Casey Gear and Maintenance Articles 0 10-12-2003 08:00 PM
stainless cleaner dvpamenter Gear & Maintenance 0 03-01-2001 01:37 PM
