Old 03-29-2010
QuickMick's Avatar
QuickMick is on a distinguished road
pendant-wire or rope?
i need to affix a pigtail to my genny to address a halyard wrap problem. a dockmate gave me a wire one that he no longer needs, but given it was custom fit to his application, im leary about the odds of it fitting mine.
i have read that i can alternativly use the same line that my halyard is to make one out of rope. any thoughts on a rope pendant, safety or otherwise? should i just have a custome wire one made for any reason?
ive got so many projects going im starting to confuse myself. again.
thanks
How inappropriate to call this planet Earth when it is quite clearly Ocean ~ Arthur C. Clarke
Quinn McColly
Yacht Broker
Old 03-29-2010
Gene T's Avatar
Gene T is on a distinguished road
I made up a wire one at WM using their equipment. Didn't cost much really. But halyard material should work just fine.
Gene
Currently in Long Beach, CA
Old 03-29-2010
IMHO, you're better off using one made up of wire, as it will transfer the torsional loading of the roller furling unit a bit better than a rope pendant will.
Old 03-29-2010
paulk's Avatar
paulk is on a distinguished road
Wire might hold up better to chafe than line, as well. That's why lifelines are usually wire. If the piece you got from down the dock is too long, you can always cut it to fit and (double) nicopress a new eye where you need it, as suggested above. Just be sure to measure twice and cut once.
Possibly a stripped halyard? SiXeVeN Gear & Maintenance 9 06-12-2011 11:00 PM
Keeping Wiring Woes at Bay Chris Brignoli Gear and Maintenance Articles 0 01-26-2004 07:00 PM
Electrical Work Rules Don Casey Gear and Maintenance Articles 0 07-16-2000 08:00 PM
