03-29-2010
Tip, not looking to cheat Rigrite or anything but rather than doing butt wleding on aluminum plate? I'd say to just take the plate to a local machine shop and ask them if they can bend up a piece of similar aluminum stock, but use a piece that's two inches longer. I'm guessing they might charge you $100 for a piece of metal, bent, with two slots cut in it the same way. Anodizing it is going to cost something more, maybe another $25-40 if you can drop it off at a shop that's doing a batch of other stuff at the same time.
Heck, maybe someone at Rigrite could just have one made up a few inches longer if they used their imagination, that plate has to be CUT DOWN from a larger sheet at some point anyhow.
