Windlass wiring - SailNet Community
post #1 of 33 Old 03-30-2010 Thread Starter
Windlass wiring
Doing the final hook ups on a Lewmar Pro 1000 on my Tartan. I was wondering how to hook up the cables to the battery. I have 3, 12 volt batteries for my house bank so do I hook up the ground to say battery 1 and the positive to battery 3 or does it matter as long as the ground is on the ground of a battery and to positive is on one of the three positive terminals?
saildog1 is offline
post #2 of 33 Old 03-30-2010
Ideally, you'd want to hook up the ground to the last of the three paralleled batteries and the positive to the first...so that all three are loaded as equally as possible by the windlass.
However, I do have to ask, why are you wiring the windlass directly to the batteries? It should be going through a switch and circuit breaker or fuse.
Also, how far is the run from the battery bank to the windlass and what size wire did you use? Undersizing the wiring to a windlass is a very common error and greatly shortens the life of the windlass.
sailingdog is offline
post #3 of 33 Old 03-30-2010 Thread Starter
I forget what size I ordered from Genuinedealz but they were huge and I have about a 3 amp drop based on the chart on the web site. The cable size is larger than 1/2 inch close or equal to 3/4 and pretty expensive. They do go through the breaker supplied by Lewmar but they also have to go to the batteries. I'll attach them as you recommend, Thanks.
saildog1 is offline
post #4 of 33 Old 03-30-2010 Thread Starter
2/0 that was the size
saildog1 is offline
post #5 of 33 Old 03-30-2010
I hope you meant a 3% drop, not a 3 amp drop.
post #6 of 33 Old 03-30-2010
mitiempo's Avatar
Ideally you will have all the battery grounds going to a busbar and then to the engine ground point. Multiple grounds can cause problems. The windlass has a breaker but should also have a dedicated switch near the batteries. Even with a breaker if it shorts out and turns itself on damage can occur before the breaker goes.
Brian
mitiempo is offline
post #7 of 33 Old 03-30-2010
Glad I found Sailnet
Bene505's Avatar
The windlass has to be the largest amp draw with the probable exclusion of the starting batteries, and perhaps not since the starter is only "on" for short periods, while raising an anchor can take a few minutes. ANd the starter is not usually on the house bank.
If connecting to a bus bar (which sounds like a good idea IMHO), the cable from the bus bar to the negative terminal has to be thick. Otherwise it will raise the voltage of ground.
Regards,
Brad
Great minds discuss ideas;
Average minds discuss events;
Small minds discuss people.
The best minds discuss sailing (and a little bit of politics). I don't know why. It's a mystery!
Bene505 is offline
post #8 of 33 Old 04-01-2010
Saildog1: I will be going thru exactly the same process on my Pearson 365 in a few weeks. Lewmar Pro Series 1000 wired to the house bank (via the supplied circuit breaker, rocker switch and contactor box. I'll be ordering the wire, also, from Genuinedealz based on the recommended sizing-for-length-of-run chart in the windlass' manual. Any pitfalls I ought to be aware of before I start?
[/SIGPIC]Dave
Sailing out of Seward, Alaska
"Fight the good fight, holding on to faith and a good conscience. Some have rejected these and so have shipwrecked thier faith"
dave6330 is offline
post #9 of 33 Old 04-01-2010
mitiempo's Avatar
dave
This is a good calc to use for wire size. AWG by wire length/amps calculator
Best to size for 3% or less drop for long windlass life and more efficiency. Manuals suggest 10% is ok but 3% is a lot better.
Brian
mitiempo is offline
post #10 of 33 Old 04-01-2010 Thread Starter
I found genuinedealz was the cheapest and it is all tinned wire. I bought everything from them to wire it up and made my own cables also. I borrowed a rather large crimping tool from our diesel mechanic where I work. Running the cable is the toughest part of the job. I have a Tartan 3800 and was able to follow the air conditioner lines to the bow. There is a chart on the genuinedealz site to determine the size of cable to use. I raun a string from the batteries to where I mounted the contactor in the V berth and then from the contactor to the anchor locker. I also mounted a 1/4 inch backer plate under the windlass for serious support.
I'm lucky to have mechanics where I work to let me use their crimpers and have them make ke up backer plates. They do great work.
I also bought the wireless remote for the windlass. I splash next week and will give it all a try. I bought the windlass at Defender.
saildog1 is offline
Windlass wiring aphil138 Gear & Maintenance 21 01-12-2007 08:04 PM
Choosing and Installing an Electric Windlass Sue & Larry Gear and Maintenance Articles 0 09-06-2002 09:00 PM
The Great Windlass Debate SailNet Seamanship Articles 0 11-30-2001 08:00 PM
The Great Windlass Debate SailNet Gear and Maintenance Articles 0 11-30-2001 08:00 PM
Wiring Windlasses Sue & Larry Gear and Maintenance Articles 0 05-19-2001 09:00 PM
