Old 03-30-2010
Zincs for Max Props
I've been lucky enough to score a 3 blade max prop, exactly the size recommended by PYI, and matching shaft size too, for a steal of a deal.
However the prop zinc is gone, of course, as are the fasteners for it.
Two questions:
In West Marine, the "PYI" zinc is $100, the generic knock-off $15. Is there value in going with the original?
Do they specify bronze or SS bolts to hold the zinc on?
1984 Fast/Nicholson 345
Old 03-30-2010
Fstbttms's Avatar
I don't discuss my member
Fstbttms is on a distinguished road
Two questions:
In West Marine, the "PYI" zinc is $100, the generic knock-off $15. Is there value in going with the original??
No.
Use stainless.
"Clean bottoms are FastBottoms"
Old 03-30-2010
speciald's Avatar
Special Delivery
speciald is on a distinguished road
Send a message via Skype™ to speciald
Goto the PYI web site. They sell the screws - stainless with hex heads and the proper thread. They also sell a "box" with a number of zincs and the needed screws. $100 sounds like alot for one zinc. A box of 3 - 83mm zincs + three screws is $55 on their site.
Old 03-30-2010
Fstbttms's Avatar
The West Marine Max Prop "kit" includes two zincs, fasteners for both, allen wrenches and sandpaper. But it's still an outrageous price.
Old 03-30-2010
Thanks much gentlemen...
Old 03-30-2010
PorFin's Avatar
Señor Member
PorFin is on a distinguished road
FWIW -- West Marine's list prices are indeed steep, but with a little work (and a printer) you can save yourself some cash by taking advantage of their price matching policy. Print out a copy of the listing of the best price you can find on the item you want, then (politely) challenge the price at the WM check-out counter. I just replaced my dinghy's Aqua-Signal portable all-round light, and the local WM matched Defender's Winter Sale price which reduced WM's price by almost $10.
Of course, we may be talking apples and pomegranates in this case if WM's prop kit is something they package in-house.
BTW: I'm not affiliated with WM, just an all-too-frequent customer.
Old 03-30-2010
wwilson's Avatar
Chesapeake Sailor
wwilson is on a distinguished road
Faster,
I bought 3 zincs each from the following two sources some years ago. I haul annually and keep the zinc from the prior season for comparison. There is virtually no difference in wear: each about 30% in a season, most of that around the fitting screws area. (I will be interested to try this season the plastic liners mentioned recently in another thread.)
PYI Inc. Max-Prop
Max_Prop_Propeller_Zinc_Anodes
Wayne
s/v Virginia Dare
Old 03-30-2010
Fstbttms's Avatar
I don't personally understand the rationale behind using the screw liners. The screws aren't causing the depletion of the Max Prop zinc in that area. The zinc depletes from the surface inward. The reason the Max Prop zincs deplete at the screws first is that the material is thinnest at that point.
Old 03-30-2010
saildog1 is on a distinguished road
try boatzincs.com they are about $7.20 for the one I use on my 3 blade maxprop. They also have the screws for a few bucks. I buy from them every few years to get the free shipping.
Old 03-30-2010
wwilson's Avatar
Chesapeake Sailor
Yeah, I don't either but you have seen the posts.
Wayne
s/v Virginia Dare
zincs for lead. feetup Gear & Maintenance 21 10-10-2006 10:36 AM
Zincs for Sail Prop feathering prop jrbarn Gear & Maintenance 4 09-20-2006 10:40 AM
outboard zincs SteveHill Gear & Maintenance 1 01-01-2004 10:32 AM
ProWell Prop Zincs! alohakate1 Gear & Maintenance 1 09-06-2002 01:25 PM
Painting Props and Shafts Dan Dickison Her Sailnet Articles 0 05-08-2001 08:00 PM
