04-17-2010
I'd second using a bosun's chair. I'd also point out that many spreaders have either a clamp or wire seizing them to the shroud, which means you need to go aloft to manually fix it and then re-clamp or re-seize the spreader tip to the shroud.
Well, it's going to take quite a bit of working on my wife to do this - or we'll have to sneak around behind her back. When I first brought up the idea of sending up my 23 year old son (who is a firefighter accustomed to heights) she literally broke out into cold sweats. Then I made it worse by saying, "OK, I'll go up," and she broke into tears and cold sweats.
Assuming I figure a way around this problem, I do have a rational safety concern that needs your advice. Should someone really go up in a bosun's chair with the upper shrouds loosened? What if, after removing the seizing wire or clamp, the shroud comes off the spreader tip and luffs (or whatever the term is for that)? Wouldn't there be some risk of the rig coming down or swaying so much it endangers the guy in the chair?
1998 Catalina 250WK "Take Five" (at Anchorage Marina, Essington, on the Delaware River)
1991 15' Trophy (Lake Wallenpaupack)
