Old 03-31-2010
jwreck is on a distinguished road
Cutting the keel???
Is this really done? Is it even remotely cost effective? How bad does it mess with a boat's performance?
Old 03-31-2010
mitiempo's Avatar
Why on earth would you ever want to cut a keel? If much weight is taken off the boat will not be able to stand up to its sail area as designed. If a boat was to be so modified it should be after a redesign by a respected naval architect.
Cost effective? How?
Brian
Old 03-31-2010
deniseO30's Avatar
Lies about her age
yet many older center board/drop keel cruisers have the slot filled in because the owners don't/won't/can't/don't know how to deal with it. Which to me translates as the same thing.
Old 03-31-2010
PeterSailer's Avatar
Bathurst NB
PeterSailer is on a distinguished road
Yes it has been done.
check out there links...
MarsKeel Technology Keel Draft Reductions
http://www.marskeel.com/fckeditor/us...ng%20World.pdf
Keep It Simple!
Old 03-31-2010
TQA's Avatar
TQA TQA is offline
Bombay Explorer 44
TQA is on a distinguished road
CSY 44s were designed to be able to slice off the bottom foot of the keel.
The idea was after they were finished chartering they could have their draft reduced for Florida / Bahamas sailing.
Old 03-31-2010
mitiempo's Avatar
Peter
Shortening a keel and bolting on torpeedo shaped lead to it is a lot different than just cutting 500 or 1000 lbs off. As well with shallower draft there would have to be more ballast than there was originally in a deeper keel to maintain the same stability.
Denise
Eliminating an unballasted centerboard will affect pointing ability but not stability. If it is a heavily ballasted centerboard that is removed it will change stability. If the ballasted board is just kept in the slot it is no different than forgetting to lower it. While not as low the weight is still there.
TQA
The key word is "designed".
jwreck
Exactly what are you planning to do?
Brian
Old 03-31-2010
Bathurst NB
Peter
It says the exact same thing in the second link I posted.
For obvious reason you can't cut off 500-1000lbs of lead off your keel without adding a bulb... But it's possible to reduce draft.
Keep It Simple!
Old 03-31-2010
mitiempo's Avatar
Which leaves us wondering exactly what jwreck has in mind. His question was pretty vague.
Brian
Old 03-31-2010
scottyt is on a distinguished road
my 83 hunter 27 is a shoal keel the keel weighs 3300 lbs and my draft is 3'3" the true fin keel is a foot deeper and 200 lbs lighter
just for comparison
less depth more weight to offset the leverage the keel has lost with length
Old 03-31-2010
mitiempo's Avatar
Exactly right, scotty. The same with my CS27 deep vs shoal and any other design I know of.
Brian
My First Boat...Boat Term Question... Kacper General Discussion (sailing related) 38 09-23-2008 06:52 PM
Wing, fin, or bulb...what are the trade offs? langousta Gear & Maintenance 17 09-17-2008 04:54 PM
reducing keel/adding fin? abacosol Gear & Maintenance 9 07-01-2007 09:32 PM
Keel Bolt Repairs Don Casey Gear and Maintenance Articles 0 11-10-2003 07:00 PM
Keel Bolt Concerns Don Casey Gear and Maintenance Articles 0 10-12-2003 08:00 PM
