03-31-2010
you could go to a machine shop and have one made, the only issue would be shaft length. the adapter might be as short as 1 inch, but probably more. the best bet would be to have a custom coupler made for the shaft that takes the larger shaft with the smaller bolt pattern.
cost at least a few hundred, and i would have 2 made so you have a spare. the cost for the second would be cheaper as they would have the setup ready.
