Old 04-01-2010
velero's Avatar
PR Sailor
velero is on a distinguished road
Check alve - in outlet of the bilge pump
Tell me again why is a bad idea to have a check valve in the bilge pump outlet. Other than it could freeze....
Old 04-01-2010
ereiss is on a distinguished road
why a check valve in bilge pump outlet?
My understanding is 1) it is not needed with a proper loop and 2) it adds resistance and constriction to the outflow.
I just removed mine last week when I replaced the pump.
Or I could be wrong.
Old 04-01-2010
Velero—
You probably should read the article I wrote on bilge pumps... the problem is that most bilge pumps are the centrifugal RULE type pumps and they don't generate much pressure. If the check valve is in the hose near the pump, it can often get a column of water in the hose beyond it...and the pump may not be able to generate enough pressure to open it against the column of water, preventing the bilge pump from operating correctly.
Old 04-01-2010
Brezzin's Avatar
Brezzin is on a distinguished road
Send a message via AIM to Brezzin
Being that your avatar picture is a Hunter 49 I understand the question. On the 49 the back-flow volume from the bilge pump lift is sufficient to cycle the pump continually. The 49 has a pretty deep bilge. I tried a check valve but that had marginal success. The back pressure on the check valve from the water in the hose required the pump work really hard to start flowing. On one occasion the hose from the check valve to the pump blew off and all the pump was doing was pumping right back into the bilge. I dropped the check valve after that. I'm going to try a different switch that has a 20 second delay before turning off. I'll mount the switch about 1/2 inch higher in the bilge. This should stop the cycling of the pump.
Dave
s/v "eclipse"
Mystic CT
2007 Hunter 49
Old 04-01-2010
Gene T's Avatar
Gene T is on a distinguished road
I have a check valve in the bilge and a Par Diaphragm Bilge Pump. The combination works well to keep my very small sump dry. I also have a 1500 Rule, an alarm and a manual pump for when things go wrong.
Gene
Currently in Long Beach, CA
Old 04-01-2010
velero's Avatar
PR Sailor
Brezzin that is exactly my problem. I did upgraded the bp from the 1500 to the 3700 model. I got a new switch comming in, but bought the check valve so I am going to try it and see if it works with the larger pump.
V49
Old 04-01-2010
T37Chef's Avatar
Senior Culinary Member
T37Chef will become famous soon enough
I don't see why you cant have "maintenance" pump, usually a small one, with a check valve...then another "emergency" pump of larger size mounted above or near it with out a check valve?
I have a Rule 500 mounted low in the bilge with a check valve and 3" above that is a Rule 3700 with smooth hose and no check valve. This keeps the water level in the bilge low or dry (I get some rain water in through the keel step mast). The large one is kept high and dry and hopefully will last a very long time
I would add that the larger pump is wired directly to the house batteries, the smaller is on a switch. This way I can never accidentally switch off the big daddy.
As for the freezing concerns...I add some antifreeze (pink stuff) to the bilge in the winter and switch the little one off after running a bit of the antifreeze through it. I check the boat every couple of weeks and cycle it if need be. Its also a good way to check if there is a leak somewhere. If the pump is continuously operating while I'm not there I wouldn't know of a slow leak unless I have a counter installed.
Shawn
S/V Windgeist
Tartan 37C #358
Photo by Joe McCary
THE Yacht Builders List:
Useful Food Purchasing Links:
Old 04-01-2010
instead of having a maintenance pump with a check valve in the line, just have a very small maintenance pump. It will minimize the water that backflushes into the bilge.
Old 04-01-2010
Red
redhead78 is on a distinguished road
I have a small flojet pump I was going to mount inline with the discharge line, with a rule float switch, to activate, this should work yes?...
Red, 77 Jeanneau Gin Fizz 38
Old 04-01-2010
A flojet pump doesn't require a check valve, because it already has them integrated as part of the diaphragm pump.
Devising a Better Bilge Pump Don Casey Seamanship Articles 0 06-02-2002 08:00 PM
Devising a Better Bilge Pump Don Casey Gear and Maintenance Articles 0 06-02-2002 08:00 PM
Devising a Better Bilge Pump Don Casey Cruising Articles 0 06-02-2002 08:00 PM
