04-03-2010
I'm surprised you've been able to pack the stuffing box so tight that it makes the steering stiff. Generally, tillers or quadrants supply so much torque that even a seizing on the rudderpost couldn't hold against their power- and you'd hardly notice any drag on the helm if there was one. Maybe something else is making the steering stiff. If you have a wheel, did the quadrant shift out of alignment, or are the cables tighter than they were before? If you've got a tiller, has the tillerhead shifted on the rudderpost so that it's now chafing on something? Is there a seal that you've tightened more than it was before? I would hope it would loosen up some once it's wet, but if it doesn't... are you going to haul again to repack it? That might be overkill. I'd check the steering system overall, and not worry about it if it's ok.
