04-05-2010
ASA and PSIA Instructor
Originally Posted by Nbot
...So, this is how "green" I am, I'm just assuming that all C-22's booms have the necessary equipment to run a reef, but I have no idea if I have what would be needed to run a 2nd reef (I'm getting boat out of winter shed this week so can look at the boom then if needed before ordering the sail). In my head I was just assuming that I'd just let the main down further, and run the 2nd reef clew back to the same camcleat I used for the first reef clew? This is the image/article I was partly learning from:
reefing
You are right I probably won't be out in 25mph+ winds regardless...so perhaps one reef is fine. I'm also a little confused on "which" sail would be better to run solo in heavier weather, a reefed main or my hank-on jib?.
I'll check out the link for the other sail company...thanks for the suggestion sailfool.
There's been a thread about using one reefing line for both reefs, IMHO it,s not a good or practical idea. I've always seen two reefing lines for two reefs, but you could search for the thread and see what the advice was.
To support two reefs, you need provision in the boom passing for two reefing lines (which most booms will have, if not for three), two lines (one shorter, one much longer), plus either a loose-foot main or two grommets located in the foot below the reef positions. This tread works the subject over well:
http://www.sailnet.com/forums/learni...youve-got.html
Your boat will sail best with a small jib and a reefed or double-reefed main, then OK with just the jib (anticipate leeward helm), but will be an un-responsive dog with just the full main, or a reefed main. If your boat were a fractional rig with a large main, then the main alone is a more practical option
