Old 04-04-2010
davidpm's Avatar
davidpm is on a distinguished road
Is this cleat upside down?
Actually this one is right side up.
I meant to take a picture of a cleat on the other side of the mast that was the opposite.
It is a pet peeve of mine that so often cleats are just exactly the minimum size to possibly work. Like this one.
Old 04-04-2010
Pub911 is on a distinguished road
i don't think so. wrap under then up and then down again (360 at this point) into the "jam" side.
Old 04-04-2010
poopdeckpappy's Avatar
poopdeckpappy has a spectacular aura about poopdeckpappy has a spectacular aura about
I agree w/ Pub
1978 Tayana 37
Freedom comes when you’re ready to sail away. True freedom comes when you don’t have to return
Cut off from the land that bore us, betrayed by the land we find, where the brightest have gone before us and the dullest remain behind, .......but stand to your glasses, steady,.......tis all we have left to prize, raise a cup to the dead already, hurrah for the next that dies
Old 04-05-2010
tager's Avatar
tager is on a distinguished road
Small cleats annoy me too.
Old 04-05-2010
deniseO30's Avatar
Lies about her age
I believe the "jam" side is up so gravity helps the line stay put although it wouldn't matter on the horizontal
Old 04-05-2010
roline's Avatar
Cal 9.2 SilverSwan
roline is on a distinguished road
It should run through the turning side and jam on the other. It it is the other way it is a *!%#*%!! to get off.
Cal 9.2 #19 SilverSwan
Old 04-05-2010
Izzy1414's Avatar
..........huh?..
Izzy1414 is on a distinguished road
I would think that which way a cleat on the mast is oriented would be dependent on what its intended use was. I could envision one mounted the opposite of a halyard cleat for something like a cunningham or an out haul, depending the way they were rigged.
S/V Boccata d'Aria
I'm not sure what Dickens are, but I think they may be important and I sure as hell don't want them scared out of me.......Izzy
Old 04-05-2010
No, that cleat is mounted properly... you never want the jam side of the cleat to be taking the initial wrap from the line... it can make it almost impossible to free the line if the load is too heavy, and dangerous besides. Also, as DeniseO30 says, gravity is helping as well... but that's a minor consideration compared to the danger of the load being on the jam side of the cleat directly.
Old 04-05-2010
Izzy1414's Avatar
..........huh?..
Uh huh, as well as the fact that you really can't tension the line properly if the first wrap goes around jam side first. Pulling on the line will jam the line in the cleat instead of tightening the working end of the line.
S/V Boccata d'Aria
Old 04-05-2010
what do ya mean.... you're supposed to tension these lines??? damn, that explains so much....
Lead Lines Aft on the cheap MtHopeBay Gear & Maintenance 22 12-09-2009 04:57 PM
Another way to cleat davidpm General Discussion (sailing related) 16 09-25-2009 03:27 PM
Hold That Line Tom Wood Gear and Maintenance Articles 0 10-03-2002 08:00 PM
Cleat?? sailboter97 Gear & Maintenance 4 04-08-2002 05:25 AM
Schaefer Mid-ship Cleat Mark Matthews Gear and Maintenance Articles 0 10-01-2000 08:00 PM
