Climbing Rope - Page 2 - SailNet Community
post #11 of 24 Old 04-05-2010
redline's Avatar
are there any kids aboard, especially boys? should be a good rope for them to tie each other up with, at least it would keep them from using your running rigging for the purpose. ;-)
Norman
s/y "Redline"
1998 Jeanneau SO45.2
redline is offline
post #12 of 24 Old 04-05-2010
I wouldn't recommend using USED climbing rope as your anchor line. That strikes me as particularly penny-wise and pound-foolish. You don't know what stresses the rope has been exposed to.
sailingdog is offline
post #13 of 24 Old 04-05-2010
I do use retired climbing rope for my double line reefing setup, on both 1st and 2nd reef points. Although it does stretch a bit, when you winch it tight, the reef points certainly stay where they are supposed to. So, in my experience, the stretch is not a problem. The strength / size of the line is likely way overkill for a reef line, but free is free, and it works fine.
I also have used it in the past, to tightly tie down a tarp over the boat, when stored outside for the winter.
Northeaster is offline
post #14 of 24 Old 04-05-2010
tager's Avatar
Get it! Extra rope is a good thing. You will find a use.
tager is offline
post #15 of 24 Old 04-05-2010
pdqaltair's Avatar
You have a good point... but...
I can tell you to a good degree of engineering precision what stress a gym climbing rope can see. A force of over 500 pounds is nearly impossible to create in a gym because of the design of the facility. Gyms are designed to control the climbing experience and to control the liability of the owner. The use cycles of climbing ropes have been studied to exhaustion and are far better understood than is obvious. Breaking a modern climbing rope is practically unheard of (cutting over a sharp edge is a different manner - that happens rarely) and gym ropes are fatter than the ones used in the mountains.
Can you say a much about the history of an anchor rope that has been through one good storm? Was the anchor rope, when new, subjected to the same QC and research effort that a climbing rope is? Does it contain 12-16 completely independent cores for redundancy and reliability under life-and -death pressure? Climbing ropes are a whole different sort of high-tech cordage and the prices reflect that.
Just something to think about. The whole business of when to retire equipment is quite complicated.
For all to hear, I suggested the use only for boats under 2 tons. They have a very easy hand and are extremely comfortable to work with; however, used is used and they will not work with a windlass.
Writing full-time since 2014
"Keeping a Cruising Boat for Peanuts"
"Faster Cruising for the Coastal Sailor"
"Singlehanded Sailing for the Coastal Sailor"
pdqaltair is offline
post #16 of 24 Old 04-05-2010
PDQAltair—
As a former climber, I'm fairly familiar with modern lines, both sailing and climbing. Most gym climbing ropes are relatively short, since the climbs are somewhat constricted in their height. Most would not be suitable for use as anchor rodes, due to their length.
The longer ropes that might be suitable for anchor rode use are not generally used in an indoor or controlled climbing environment—and they most certainly could have been exposed to loads greater than 500 lbs.
post #17 of 24 Old 04-05-2010
poopdeckpappy's Avatar
Get enough footage ( of same color ) and make some ratlines
1955 Blanchard 51 Custom ( I got a woody )
1974 Ranger 33
Friends don't let friends do stupid things alone
poopdeckpappy is offline
post #18 of 24 Old 04-05-2010
pdqaltair's Avatar
Yup, outdoors is different. Caught a guy taking a 120' whipper years ago.
PDQAltair—
He was a little spooked after that.
Even at that, the load probably never hit much over 1000 pounds, since there was ~ 120 feet of rope out (as you know, forces approach 2500 pounds, but only with a 1.8 fall factor). The knot was not hard to untie, and I was barely lifted from the ground. It was a youngster, not my regular partner, and he thought running it out would be cool, I guess.
post #19 of 24 Old 04-05-2010
pdqaltair's Avatar
How do we determine the life of a rope?
Serious question, all jousting aside.
An anchor rope on a smallish boat could easily see a 500-pound yank every 10-30 seconds for the 10 hour duration of a front passage. That is 1800 cycles.
A climbing rope in a gym could see 20 x 500 pound falls in a day, or 1800 cycles in 90 days.
We can adjust the numbers; the point is that the order of magnitude is similar. The gym association - there is one - has set an expiration date based upon a very strict standard because a failure will always mean serious injury or worse, but to my knowledge has not seen a fatigue related failure. Clearly, we are not going to retire an anchor rode after one significant blow, not an epic storm at all. The gym rope has not seen salt or UV. Neither has seen strain beyond the SWL. Presumably neither has significant fraying. How do we decide?
My gut and any engineering approach I can reason suggests that the retirement age of a climbing rope from critical service is only a very small fraction of its useful life in other services. A climber may fall a distance, but weighs 6000/150=40 times less than the boat. That is material.
We don't know.
post #20 of 24 Old 04-06-2010
baDumbumbum
bobmcgov's Avatar
This. Many climbing gyms do not even offer lead walls, for liability reasons. The forces generated from toprope falls are trivial -- you can catch one on 10mm line with your bare hands, known in the business as a Russian Belay.
The QA and safety factors on climbing equipment are top-notch. Can't really splice kernmantle, as has been noted. But it loses little strength in knotting.
Another place for it is traveler controls; Beth & Evans use it on their traveler to limit shock loads during jibes.
Buccaneer18, Grainnia
SJ21, Diarmuid
Albin Ballad 30, Fionn
bobmcgov is offline
Possibly a stripped halyard? SiXeVeN Gear & Maintenance 9 06-12-2011 11:00 PM
pendant-wire or rope? QuickMick Gear & Maintenance 3 03-29-2010 08:23 PM
How to size rope ModMMax Gear & Maintenance 41 12-12-2006 12:16 AM
Replacing wire halyards with rope DRM Gear & Maintenance 2 03-21-2006 03:49 PM
Bosuns chair mmccoy Learning to Sail 16 07-08-2004 04:16 PM
