Climbing Rope - Page 3 - SailNet Community
post #21 of 24 Old 04-06-2010
pdqaltair's Avatar
A shock absorbing traveller - hadn't thought about that.
Originally Posted by bobmcgov View Post
Another place for it is traveler controls; Beth & Evans use it on their traveler to limit shock loads during jibes.
It wouldn't absorb much, if you have enough purchase; still, my traveller line is getting tatty and I do have a newly retired 8.6 mm ice rope that would fit nicely. Since I don't fall leading ice, it only has raps on it .
Writing full-time since 2014
"Keeping a Cruising Boat for Peanuts"
"Faster Cruising for the Coastal Sailor"
"Singlehanded Sailing for the Coastal Sailor"
pdqaltair is online now
post #22 of 24 Old 04-06-2010
A friend of mine who used to work in an outdoor ed centre collect the used ropes and plaited them together into a 300 mtr drag rope for running off in storms ,dont think he ever tried them .K
mintcakekeith is offline
post #23 of 24 Old 04-06-2010
baDumbumbum
bobmcgov's Avatar
Obviously. You are alive to testify. I've often wondered if Snargs were invented mainly to give ice climbers something else to bash, or to distract themselves from the chunks of ice bouncing off their helmet. Yer a different breed, you guys are.
One thing about climbing ropes: their loosely-laid nylon cores sponge up a tremendous amount of water, and they allegedly lose quite a lot of strength when saturated -- the ability to elongate quickly & dissipate heat. Is this effect common to all nylon ropes? Is it just factored into anchor rope strength ratings? And do polyester materials experience similar de-rating when they get wet? Or -- since they are effectively static lines -- does it matter less?
Buccaneer18, Grainnia
SJ21, Diarmuid
Albin Ballad 30, Fionn
bobmcgov is offline
post #24 of 24 Old 04-06-2010
I've only hung on a Snarg to rest, and that was scary enough! Can't imagine the pucker factor of falling on one of those.
Plumbean is offline
Possibly a stripped halyard? SiXeVeN Gear & Maintenance 9 06-12-2011 11:00 PM
pendant-wire or rope? QuickMick Gear & Maintenance 3 03-29-2010 08:23 PM
How to size rope ModMMax Gear & Maintenance 41 12-12-2006 12:16 AM
Replacing wire halyards with rope DRM Gear & Maintenance 2 03-21-2006 03:49 PM
Bosuns chair mmccoy Learning to Sail 16 07-08-2004 04:16 PM
