Old 04-05-2010
JimTschet is on a distinguished road
Keel finish
Last spring I sand blasted and barrier coated (with epoxy) my steel keel on my Hunter 40. I then put Pettit Unepoxy bottom paint on the keel. When I took the boat out last fall, much of the bottom paint had flaked off the keel. A few small spots of rust show but the keel looks fairly clean. What is the best way to apply Pettit Unepoxy bottom paint to a newly epoxied steel keel (fresh water)?
Old 04-05-2010
Gene T's Avatar
Gene T is on a distinguished road
I would think you need to remove the blush on the epoxy and then use a suitable primer prior to applying any bottom paint.
Gene
Currently in Long Beach, CA
Old 04-05-2010
scottyt is on a distinguished road
blush is only a problem with some epoxys, i dont think it is with barrier coat. but you do need to do a "hot" coat.
what this means is you need to apply the bottom paint when the epoxy is just barely tacky. you might get away with just a sanding, but a better idea is a coat of either epoxy or barrier coat then once it cures enough to take a finger print but not stick to the finger give a quick coat of bottom paint. this allows a slight chemical bond from paint to epoxy
Old 04-05-2010
ASA and PSIA Instructor
You shouldn't need a primer on epoxy, but I'd let Pettit speak for themselves at (800) 221-4466. That your paint came off implies you do need to do something different. If you put more than two-three coats of paint on, don't. A thick layer of paint is the classic cause of flaking.
If you don't want more rust again next season, you need to take down any rust spots to white metal and start the epoxy over again.
(800) 221-4466
(800) 221-4466
(800) 221-4466
Old 04-05-2010
Thanks for the reply. My plan is to strip and re-epoxy the rust spots. I have contacted Pettit and am awaiting a reply.
Old 04-05-2010
Freesail99's Avatar
Freesail99 will become famous soon enough
Not sure of the brand of epoxy you used last time but I used Mas flag epoxy on my boat and the same paint as you and had no problems.
S/V Scheherazade
My First Boat...Boat Term Question... Kacper General Discussion (sailing related) 38 09-23-2008 06:52 PM
Wing, fin, or bulb...what are the trade offs? langousta Gear & Maintenance 17 09-17-2008 04:54 PM
reducing keel/adding fin? abacosol Gear & Maintenance 9 07-01-2007 09:32 PM
Keel Bolt Repairs Don Casey Gear and Maintenance Articles 0 11-10-2003 07:00 PM
Keel Bolt Concerns Don Casey Gear and Maintenance Articles 0 10-12-2003 08:00 PM
