Bedding Deck Hardware With Butyl Tape - Page 14 - SailNet Community
 57Likes
post #131 of 424 Old 09-10-2011 Thread Starter
Maine Sail's Avatar
Originally Posted by WDSchock View Post
It is difficult to express in a job title the subtle and complex nature of the craftsmanship of a ships carpenter.
Unless one has tried it with one's own hands.......
Amen to that!
______
-Maine Sail / CS-36T
Maine Sail is offline
post #132 of 424 Old 09-11-2011
Bedding deck hardware with butyl tape
In reply to Main Sail:
We do use Sika 295UV at Morris, primarily in applications where installation calls for a larger, "beauty-bead" type backfill. Certain window and portlight installations, for example.
Thanks again.
Morrisrules is offline
post #133 of 424 Old 09-12-2011
Well done! I am about to embark on much of this work and am glad to see this posting.
littlelizzy is offline
post #134 of 424 Old 10-08-2011
TakeFive's Avatar
My boat has a transom mounted rudder with pintles and gudgeons. I will be replacing the gudgeons this winter due to some wear-induced damage on one of them. I looks like the OEM installation actually used a rubber or vinyl gasket material.
For my replacement, would butyl tape be an appropriate sealant, or should I use a curing sealant. If so, what type of sealant would you recommend?
2001 Catalina 34MkII Breakin' Away (at Rock Hall Landing Marina)
PO of 1998 Catalina 250WK Take Five (new owners relocated to Baltimore's Inner Harbor)
1991 17' Trophy (Lake Wallenpaupack)
TakeFive is offline
post #135 of 424 Old 10-14-2011
TakeFive's Avatar
Any answers to my questions?
TakeFive is offline
post #136 of 424 Old 10-14-2011
Sunsets and Warm Beer....
LandLocked66c's Avatar
I used butyl tape on my gudgeons.
1971 23' Oday Pop Top
S/V Frida
You can't steer a boat that isn't moving? Just like a life - P. Lutus
LandLocked66c is offline
post #137 of 424 Old 10-14-2011
mitiempo's Avatar
Butyl is fine if they are above the waterline. I would use Sika 291 or 4200 if below the waterline.
Brian
mitiempo is offline
post #138 of 424 Old 10-14-2011
TakeFive's Avatar
Thanks for the advice. If the gudgeons are below the waterline, then I have bigger problems than my rudder!
TakeFive is offline
post #139 of 424 Old 10-14-2011
mitiempo's Avatar
The lower gudgeon is below the waterline on many boats - mine included.
Brian
mitiempo is offline
post #140 of 424 Old 10-15-2011
TakeFive's Avatar
I was just joking, but thanks for your comment. Although both of my gudgeons are above the waterline at rest, a full cockpit in following seas may cause the lower gudgeon to be submerged, or at least deluged by waves. In light of this, I'll go with a curing sealant instead.
TakeFive is offline
Techniques for Removing Teak Decks Sue & Larry Buying a Boat Articles 0 11-24-2003 07:00 PM
Mounting Deck Hardware Tom Wood Gear and Maintenance Articles 0 06-25-2002 08:00 PM
