Like Tree26Likes
  #141
Old 10-16-2011
SkywalkerII is on a distinguished road
Chainplates
I'm rebedding everything on my Tartan 27 as part of a total restoration of the deck, including partial recore. The area around my chainplates was recored. I isolated the area directly around the plates with thickened epoxy to form a block to protect the new core.
I'm thinking about how to re seal the chainplates. My T27 chainplates emerge through the deck without a plate screwed to the deck. If I use butyl tape, do I need a plate to form mechanical pressure?
Thanks
Skywalker
T27 # 249
  #142
Old 10-16-2011
mitiempo's Avatar
Butyl does need to be in compression to be effective.
A good idea would be to form a glass riser where the chainplate emerges through the deck - it will avoid water pooling around the chainplate. You can put a plate on if you wish. The link below explains - scroll down a bit.
Maintenance Log for Syzygy
Brian
  #143
Old 10-17-2011
Thanks for the help. The Tartan has an elevated section where the chainplates emerge already.
Nice link.
Skywalker
T 27 #249
  #144
Old 10-17-2011
davidpm's Avatar
davidpm is on a distinguished road
Without a plate added to the design of the picture above do you think it will hold well. Seems like the space around the chain plate filled with butyl will get embedded with dirt.
Also without the plate where is the compression coming from?
  #145
Old 10-17-2011
mitiempo's Avatar
David
I guess you didn't go to the link I provided. Here are 2 later pictures.
Bedding Deck Hardware With Butyl Tape-g4z09981.jpg   Bedding Deck Hardware With Butyl Tape-g4z1131.jpg
Brian
  #146
Old 10-17-2011
davidpm's Avatar
You are right I didn't follow the link.
Glad I did this time. A lot of great pictures. Thanks!
What confused me was the comment that the plate could be added if he wished.
It looks like it is pretty much required if butyl is to work properly.
Do you agree or am I reading too much into it?
  #147
Old 10-17-2011
mitiempo's Avatar
David
I think you could add a plate without the raised portion and it would work well. The pics show the same thing I did as it avoids the chainplate exit sitting in a puddle. It lessens the chance of a leak even further.
Brian
  #148
Old 10-17-2011
davidpm's Avatar
Sounds good.
The plates on some boats I've seen were just stamped sheet metal. The ones in the picture looked like solid stainless.
Were they made with official machine shop tools, milling machine etc or do you have some way to make them with lower end tools?
  #149
Old 10-18-2011
mitiempo's Avatar
My plates are thicker as well. Any shop that works with stainless can cut them out for you. Stainless isn't that hard to drill but machining a slot is beyond basic tools.
Brian
  #150
Old 10-18-2011
davidpm's Avatar
That's what I thought.
Just wanted to make sure I wasn't missing some cool home-brew trick.
You may post attachments
You may edit your posts
Techniques for Removing Teak Decks Sue & Larry Buying a Boat Articles 0 11-24-2003 07:00 PM
Mounting Deck Hardware Tom Wood Gear and Maintenance Articles 0 06-25-2002 08:00 PM
SEO by vBSEO 3.6.1
