Like Tree8Likes
  #161 (permalink)
Old 01-13-2012
CorvetteGuy's Avatar
72 C&C Corvette
CorvetteGuy is on a distinguished road
I bedded the windows in a shark with it last year, there was also a rubber seal that slips into the metal frame. the tape worked great as it held the plexi in place while installing the rubber gasket.
  #162 (permalink)
Old 01-13-2012
Maine Sail's Avatar
Originally Posted by kleinlax View Post
Looking for a way to seal my windows on a Beneteau First 35S5, could this be used for window bedding?
Thanks
GOM cruising
We'd need to know more about the ports... Frame, frame-less, acrylic dead lights? A photo would help..
______
-Maine Sail / CS-36T
  #163 (permalink)
Old 01-16-2012
gveto
gveto is on a distinguished road
Catalina 34 new chain plate design
Great documentation on all your work.
I recently made new chain plates for my Catalina34 and I have a short video which shows why I did it and it shows the new design. Just for your interest.
Go To YouTube link:
Catalina 34 and 36 new chain plate design - YouTube
Thanks
  #164 (permalink)
Old 02-05-2012
tominny is on a distinguished road
Butyl tape afficinados,
In what temperature range can butyl tape be applied to bed deck hardware and port lights? Since there doesn't seem to be any cure time, can I apply it at 32 degrees? Will expansion in the summer be a problem?
Or should I wait until April? ;-)
Thanks
Thomas
Tartan 34C
New York City
  #165 (permalink)
Old 02-07-2012
Mark Johnson is on a distinguished road
Hi all,
I may have been the first experimenter to try Butyl tape in the 70s, (on my first of several cruising boat projects)...
I financed this project by working as the service manager (for 3 states) in my dad's Pella window dealership. As such, I had dozens of rolls of the stuff laying around, so used it to bed many ports, deck ports & vents on the boat. Here are the caveats...
It sticks like crazy, FOREVER, and does NOT release. With window glass in a metal frame, (if a window got broken}, we'd use red hot putty knives to cut through the sticky tape. IT IS THE ONLY WAY TO DO IT! Every 5 seconds, I'd put the putty knife back under the torch's flame, to keep the blade red hot.
So, if you have to remove something made of plastic, on fiberglas, (= "fiberglass reinforced plastic"), then you may melt one of these surfaces, in removal. SO GO FAST! Also, it never sets up, but stays the consistency of bubble gum. On a hot summer day, & especially on a horizontal surface, it compresses more with heat, and oozes out of the edge more. If you wipe off or wash the surface, this ooze smears all over the boat, and requires mineral spirits and elbow grease to remove. I regretted having used it!
If you use it, I would use it as a seal & spacer, but, given room, I'd put it well inboard of the hardware edges or flange edges. On the very edge, I'd still run a small bead of caulk around the perimiter, (which does set up), and you won't have this problem. The difficulty of removal, however, remains. On very small pieces it is not an issue, but on large deck plates it is!
Mark AKA, Delphys Marine
  #166 (permalink)
Old 02-07-2012
RhythmDoctor's Avatar
RhythmDoctor will become famous soon enough
Originally Posted by Mark Johnson View Post
...Also, it never sets up, but stays the consistency of bubble gum. On a hot summer day, & especially on a horizontal surface, it compresses more with heat, and oozes out of the edge more....
There are many different manufacturers of butyl tape, and they can have a wide range of consistencies. Intuitively, I believe that one of the key parameters is the level of crosslinking in the rubber, which anyone with knowledge of adhesive chemistry recognizes as a tradeoff between adhesive strength vs. cohesive strength. (Higher crosslinking increases cohesive strength at the expense of adhesive strength.) The optimum balance of properties can be different for various applications and environments.
I have used two different kinds of butyl tape. The first type (which I bought at an RV store) fits your description: it sticks like crazy but oozes more (especially when hot) and yields at a lower elongational stress. I wasn't totally happy with this for marine bedding, so I bought some of Maine Sail's, which has a little less adhesive tackiness but oozes much less and has a huge elongational yield prior to failure (check his website for a video that demonstrates this). I believe that it has a higher level of crosslinking, and is more suited to the environmental factors and compressive stresses of marine applications.
It is important to choose the right butyl tape, and Maine Sail's seems to strike the right balance.
1998 Catalina 250WK "Take Five" (at Anchorage Marina, Essington, on the Delaware River)
1991 15' Trophy (Lake Wallenpaupack)
  #167 (permalink)
Old 02-07-2012
therapy23's Avatar
Back to just the Jon boat
therapy23 is on a distinguished road
Agreed.
After trying the RV stuff and the "real stuff" there is a world of difference.
  #168 (permalink)
Old 02-21-2012
SHNOOL's Avatar
SHNOOL is on a distinguished road
Ok, so I have to report back.. This tape is awesome! I've yet to use it for my boat, but then, I'ved used it on my Living Quarters Horse trailer, in a bunch of places.
Very elastic, easy to manipulate, and a best choice for waterproofing.
  #169 (permalink)
Old 02-21-2012
mitiempo's Avatar
You live in a horse trailer?
Brian
  #170 (permalink)
Old 02-25-2012
GilStump's Avatar
Member at large
GilStump is on a distinguished road
Great post! I have been using butyl to bed hardware. Nothing leaks, ever. One thing I have noticed is that after you clean off the excess, in a few days there is more excess forever squeezing out. In one application I went back everyday for several weeks and cut off little gray sticky worms of the stuff. Am I using too much? Is there a trick I am missing?
Cheers!
Gilligan Stump
s/v lunasea
Please don't google me.
Techniques for Removing Teak Decks Sue & Larry Buying a Boat Articles 0 11-24-2003 07:00 PM
Mounting Deck Hardware Tom Wood Gear and Maintenance Articles 0 06-25-2002 08:00 PM
